1 - 8 of 8 Posts
According to the pinout diagram below I am supposed to have 12v to ground on pin #4 on my harness. As it stands now I do not. I have tried with the key in all positions and with the engine running and with the headlights and running lights on and still no dice.
All other pins work perfect. I have looked in the owners manual and cannot find a dedicated fuse for this pin like the others have so I am not sure where it sources its power from. Does anyone have any advice on where to start trouble shooting this issue? Many thanks!
Satyr of the Midwest
:stupid
After you're sure the fuses are good, grab a test light or DVOM, start at the plug, then move forward, checking for battery voltage between that line and chassis ground.
shibby
Oh, and the ignition has to be in the run position to get any voltage through that pin. It's not an always-on electrical source.
There is a fuse for it under the hood, driver's side fuse box.
I must have read over the fuse chart in the manual like 5 times, I will go read again and report back. Thanks for the help.
as i recall when i had my 96 f250 in order to use the 7 pin harness i had to install a relay in fuse box under hood that came with the wiring harness. i also had to purchase a 30 amp maxi fuse to put in the empty slot also in the fuse box under the hood.
1 - 8 of 8 Posts
