1 - 1 of 1 Posts
Hey Guys, need a little help. Is there some sort of switch under the emer brake pedal that triggers the light to come on to illuminate on the dash? It's a '95 bronco that I just picked up, and as I was combing thru it, noticed the lack of a light on the dash when the e-brake was set. I looked under and around the e-brake pedal but did'nt see any type of contact switch. Did I just miss it or is it located somewhere downstream. Thanks!
An edit here.....I found the switch. Now curious if its tied in with the antilock brakes?
Ok, re-edited......no pwr to the antilock test connector. The vehicle didnt come with a manual, so I'm not psitive where the relay is, but after searching I think its the relay most inboard on the drivers side fender. Any confirmation on that? Before replacing it, is there somewhere else that I should check to see if the thing was disconnected by the PO? Appreciate it...
1 - 1 of 1 Posts
