1 - 3 of 3 Posts
none of my gauges are working, the engine temp gauge, battery voltage, fuel gauge and oil temp the only thing works is the tach and speedometer.
‘90 EB Full Custom build -Mega Truck Bogger
Im going to assume you checked your fuses already, right? Tach comes right from the motor and the speedo is seperate in your electrical system also.....so your instrument cluster could have a common power feed thats out from damage or bad fuse link .....do you have a haynes manual and can you follow the chasis electrical diagrams in the back? The manual should lead you right to it...its early right now Im going to work or i would look a little deeper at my book to help you out.....gotta be some threads on here with some schematics also..im sure try a search..i will check back later
15 amp fuse
1 - 3 of 3 Posts
