Gents,
Total noob question on engine removal and where to loosen transmission bolts. 1980 Bronco, 351M, C6, NP-208.
Just about got everything loose. My original plan was to loosen transmission insulator bolts to get some vertical flexibility. The benefit was that since the mounts are presumably in compression that loosening them wouldn't cause a change in transmission/t-case position. But, the rubber appears to be stuck to the washer/nut face, and I'm afraid I'll twist it off and make a mess without doing a bunch of work trying to free the rubber from the washer face.
So the second idea was to loosen the two screws attaching the transmission foot to the support. I know they'll loosen up, but was concerned the t-case my tilt the transmission back a bit, especially as the engine is freed from the transmission.
Is the transmission front-heavy enough that the t-case can't tilt it backward? If so, perhaps I can loosen said capscrews while supporting the front of the tranny with a jack. Get the engine up with the hoist, keep the jack in contact with tranny, and separate the two? Just don't want an unexpected transmission/t-case movement when the engine is separated.
Thanks.
Thanks.
