This morning I got the pinion cartridge removed from the rear end. It came out pretty easy. I used a small thin screwdriver to slowly get it separated and it popped out. I did scratch up the pinion depth shim in one spot so I'll need to replace it. I did measure the shim thickness and got an average which is .0100 to .0105. Got a couple of questions for re-assembly.....
Since the pinion cartridge came out in one unit with the oil seal still in place, I will take a rotational torque measurement to see what it is ( will be interesting what it reads ). When I put on a new seal and shim is it ok to torque back to this original measurement? or should I just follow the used bearing spec of 8-15 inch pounds?
Regarding replacing the pinion depth shim, Is there much of a difference between these two measurements .0100 and .0105. or how critical is this?
