1 - 18 of 18 Posts
1996 351W MAF E4OD A/T XLT A/C Auto hubs GT40P Mod
I have a 96 XLT. It was originally a 5.0 MAF calibration 6-54J-R11 E4OD A/T. I bought it sans motor. I bought a 94 F250 5.8L donor. I bought a 5.8L reman computer from Cardone with calibration F6PF-AVA. The 94 engine wiring harness plugs right in. Initially would crank but not start. I found no voltage to the injectors. Turns out the 12V pin location at the plug connection next to the relay/fuse box under the hood is different between the two. I added a new 12V pin (computer side of the plug) to line up with the hot to the injectors. Now it starts and runs smooth until it warms up. I'm getting codes for the O2 sensor on bank 2. There is only one O2 sensor plug on the bronco. I connected it to the sensor upstream of the CAT. The computer I bought seems to be looking for a second sensor (that doesn't exist and has no wiring in place). I'm guessing it is reading a lean condition as once it gets warm it starts to bog down and then will stall. If I take control with the scanner it will idle just fine and purr like a kitten. I'm thinking I can just jump the signal from the current sensor. Was hoping someone could let me know if that will work or if I need to add another sensor. Either way if someone could tell me which plug and pin bank one and back two O2 sensors come into I would be extremely grateful. I'm excited to get this build out in the road (and out to the beach for some surf fishing).
Discussion Starter #2
Let me know if more info is needed on this one thanks
Yo Tacotuesday,
I'l give you the tech info and let others tell you about welding in O2 sensor bungs in, if not in current exhaust y and after cats, etc. They may suggest obtaining the 96 O2 wire harness, etc.
I have no info on F6PF-AVA; was this taken from driver door jamb label?
To assist, see Wiring Harnesses (Location Diagrams) in 1996 Bronco Workshop Manual (partial) @ 1996 Bronco/F-Series Workshop Manual
Go to Section 18-01: Wiring and Circuit Protection
For example, Fender Apron, Right, Gasoline Engines;
#12 9F472 Heated Oxygen Sensor Assembly All Gasoline Engines Except 5.8L over 8500 and 7.5L.
Item Part Number Description
1 — Place Locator in Hole Provided
2 8496 Radiator Support
3 — To RH Headlamp
4 — To RH Park
5 — Body Grounds (Part of 12A581)
6 — To Starter Motor Relay Battery Terminal
7 11450 Starter Motor Relay Assembly
8 — To Starter Motor Relay (Part of 12A581)
9 14305 To Starter Motor Relay
10 — To 14305
11 14305 Wiring Assembly
12 9F472 Heated Oxygen Sensor Assembly — All Gasoline Engines Except 5.8L over 8500 and 7.5L
13 14B060 Wiring Assembly
14 12A581 Wiring Assembly
15 — To RH Air Bag Sensor
16 10372 Battery Tray
17 — To RH Park and Turn Lamp
18 — To Horns
19 14301 Chassis Ground
20 N621906-S36 Nut
21 N806925-S36MG Stud
22 N806327-S190 Screw
23 14B004 Sensor and Bracket Assembly
24 — Front End Sheet Metal Seal (Part of 5005)
25 — For Continuation See Main View
26 12A581 Wire Assembly
27 — Cap
A — Tighten to 10-14 Nm (7-10 Lb-Ft)
Fords naming convention is; "...Regardless of how the engine is mounted in the vehicle, conventional or transverse, the HO2S naming convention stays the same in relationship to engine banks 1 and 2. Bank 1 will always be the bank containing the #1 cylinder (Passenger Side).
Location in a 96 5.8; "...My 1996 OBDII 5.8L with Federal EPA has 3. All three are part of the Y-Pipe exhaust...which includes the 2 converters as part of the Y-Pipe assembly. There is one on each down pipe coming off the manifolds...and one after the dual converters..." by 3 speed at FSB.
My 96 5.0 has 3 just like 3 speed's; but plus one more in California Broncos.
Here are the locations:
Here is the 96 Bronco PCM Connector Pin-Out Diagram and LEGEND with Circuit Functions in a 96 5.0 and 5.8;
Pin Number - Circuit Circuit Function
1 315 (P/O) PCM to Transmission Shift Solenoid No. 2
2 658 (P/LG) PCM to Check Engine Indicator Lamp
3 Not Used
4 Not Used
5 Not Used
6 651 (BK/Y) Dedicated Ground
7 Not Used
8 Not Used
9 Not Used
10 Not Used
11 Not Used
12 Not Used
13 107 (P) PCM Flash EEPROM Power Supply
14 784 (LB/BK) 4x4 Low Range Switch to PCM Indicator Lamp
15 915 (PK/LB) J1850 Bus Negative/Data Negative (Return) to PCM
16 914 (T/O) J1850 Bus Positive/Data Positive
17 Not Used
18 Not Used
19 Not Used
20 Not Used
21 Not Used
22 Not Used
23 259 (O/R) Dedicated Ground to TFI Module
24 570 (BK/W) Dedicated Ground PCM
25 875 (BK/LB) Ground
26 Not Used
27 237 (O/Y) PCM to Transmission Shift Solenoid No. 1
28 Not Used
29 224 (T/W) Transmission Overdrive Cancel Switch to PCM
30 Not Used
31 Not Used
32 Not Used
33 676 (PK/O) Vehicle Speed Sensor Negative (Return) to PCM
34 Not Used
35 392 (P/LG) Heated Exhaust Gas Oxygen Sensor No. 3 to PCM
36 968 (T/LB) Mass Airflow Return
37 923 (O/BK) Transmission Oil Temperature to PCM
38 354 (LG/R) Engine Coolant Temperature Sensor to PCM
39 743 (GY) Air Charge Temperature Sensor to PCM
40 238 (DG/Y) Fuel Pump Monitor to PCM/Fuel Pump Relay to Safety Switch
41 198 (DG/O) A/C Pressure Switch to Control Relay
42 Not Used
43 Not Used
44 200 (BR) PCM to Air Management No. 2 (TAD in 5.0 engines)
45 Not Used
46 Not Used
47 360 (BR/PK) PCM to Electronic Vacuum Regulator Constant Current
48 382 (Y/BK) PCM to Test Connector No. 2
49 395 (GY/O) Profile Ignition Pickup to PCM
50 929 (PK) PCM to Spark Angle Pulse Width/Spark Output
51 570 (BK/W) Dedicated Ground PCM
52 Not Used
53 924 (BR/O) PCM to Transmission Coast Clutch Solenoid
54 480 (P/Y) PCM to Transmission Converter Clutch Control
55 37 (Y) Battery to Load
56 191 (LG/BK) PCM To Vapor Management Valve Constant Current
57 310 (Y/R) Knock Sensor No. 1 to PCM
58 679 (GY/BK) Vehicle Speed Sensor Positive to PCM
59 917 (DG/LG) Misfire Detection Sensor Feed
60 74 (GY/LB) Heated Exhaust Gas Oxygen Sensor No. 1 to PCM
61 Not Used
62 Not Used
63 Not Used
64 199 (LB/Y) Manual Lever Position Sensor to PCM
65 352 (BR/LG) Delta Exhaust Pressure Transducer to PCM
66 Not Used
67 Not Used
68 Not Used
69 Not Used
70 190 (W/O) PCM to Air Management No. 1 (TAB in 5.0)
71 361 (R) Power Output from PCM Relay
72 561 (T/R) PCM to Fuel Injector No. 7 Cylinder
73 559 (T/BK) PCM to Fuel Injector No. 5 Cylinder
74 557 (W) PCM to Fuel Injector No. 3 Cylinder
75 555 (T) PCM to Fuel Injector No. 1 Cylinder or Bank No. 1
76 570 (BK/W) Dedicated Ground PCM
77 570 (BK/W) Dedicated Ground PCM
78 Not Used
79 911 (W/LG) PCM to Output Circuit Indicator Lamp/Overdrive Cancel Indicator
80 926 (LG/O) PCM to Fuel Pump Relay Control
81 925 (W/Y) PCM to Electronic Pressure Control No. 1
82 Not Used
83 264 (W/LB) PCM to IAC
84 136 (DB/Y) Output Shaft Speed to PCM
85 Not Used
86 Not Used
87 94 (R/BK) Heated Exhaust Gas Oxygen Sensor No. 2 to PCM
88 967 (LB/R) Mass Air Flow Sensor to PCM
89 355 (GY/W) Throttle Position Sensor to PCM/or Diesel Fuel Injector Pump Lever Sensor
90 351 (BR/W) Power to Engine Sensors
91 359 (GY/R) Sensor Signal Return
92 511 (LG) Stoplamp (Brake On/Off) Switch to Stoplamps
93 387 (R/W) HEGO Sensor Heater Voltage Monitor No. 1 to PCM
94 388 (Y/LB) HEGO Sensor Heater Voltage Monitor No. 2 to PCM
95 389 (W/BK) HEGO Sensor Heater Voltage Monitor No. 3 to PCM
96 Not Used
97 361 (R) Power Output from PCM Relay
98 562 (LB) PCM to Fuel Injector No. 8 Cylinder
99 560 (LG/O) PCM to Fuel Injector No. 6 Cylinder
100 558 (BR/LB) PCM to Fuel Injector No. 4 Cylinder
101 556 (W) PCM to Fuel Injector No. 2 Cylinder or Bank No. 2
102 Not Used
103 570 (BK/W) Dedicated Ground PCM
104 Not Used
Thanks that is super helpful! I need to print this out and figure out why I only found one sensor plug. I've still got the original factory wiring in except for the motor. Maybe I missed a plug somewhere. Thanks again
Saw your note about the calibration. The calibration was done by the rebuilder. The old part number for the EEC would have been F6TF-12A650-AVA. Now they are calling it F6TZ for the prefix. AVA is supposed to be the same calibration as ASA. The ARA and ARB would have been different. I bought it from www.partsgeek.com part # 786689
Still learning how to post here. Didn't realize the mobile version didn't give me the direct reply and quote options. Do you know where I can get the pin chart for the 12A851 sensor wiring harness that's mounted next to the power distribution box on the driver's side fender? I can find the picture that shows the wire colors by pin but not what each pin is for. Thanks again!
aka: kemicalburns
ok so you have a 96 bronco that had a 5.0 but the motor was gone. Was the efi wiring harness still in place?
you then bought a 95 5.8 out of an F250 and are using that motor and that motors wiring harness?
What you should do is use the 96 wiring harness on the 5.8 motor, and also use the original 5.0 computer for the time being. That 5.8 motor will need the crank position sensor, there would be a star looking item that would be behind the main pulley that the crank position sensor reads off of, similar to a tone ring.
that F series harness wont work in your OBD-II setup what so ever. its also a speed density harness.
Yo,
I gave away my 96 EVTM, but think @Mikey350 may have the 12A851 info.
Here is what I have saved;
Connector Number to Wire Assembly in a 96, from 96 FORD EVTM;
C101 F 9D930
C101 M 12A581
C102 12A581
C103 F 15525
C103 M 12A581
C106 F 12A581
C106 M 18A586
C107 M 12A581
C107 F 12A690
C109 F 15525
C109 M 12A581
C112 F 14405
C112 M 12A581
C115 9D930
C116 PIA
C117 F 14K067
C117 M 15525
C119 12A581
C120 12A581
C121 12A581
C122 12A581
C123 12A581
C124 12A690
C126 9D930
C129 12A581
C130 12A581
C131 12A581
C135 9D930
C139 F 14305
C139 M 12A581
C150 9D930
C151 12A581
C152 12A581
C153 14305
C154 14305
C161 14K067
C162 18A586
C163 9D930
C164 12A581
C166 15525
C168 18A586
C169 18A586
C170 12A581
C173 F 15A702
C173 M 12A581
C177 12A581
C178 9D930
C180 9D930
C182 9D930
C183 9D930
C185 12A581
C190 9D930
C191 9D930
C192 9D930
C193 9D930
C194 9D930
C195 9D930
C196 9D930
C197 9D930
C200 F 14A504
C200 M 14401
C201 14401
C202 F 14401
C202 M 12A581
C203 F 18A586
C203 M 14401
C204 F 14401
C204 M 13A726
C205 F 14401
C205 M 14405
C206 F 17K745
C206 M 14A504
C207 14401
C209 F 14401
C209 M 14B095
C210 F 14A348
C210 M 14401
C211 19B113
C212 19B113
C213 F 14A265
C213 M 14A509
C214 M 14A504
C214 F 14A509
C217 14401
C218 14401
C219 14401
C220 14B095
C221 14B095
C222 14B095
C223 14B095
C224 14401
C226 14401
C227 PIA
C228 F 14A265
C228 M 14401
C229 F 14401
C229 M 14A504
C230 14401
C231 14401
C232 14401
C234 13A726
C236 14401
C240 14401
C241 14401
C242 14401
C243 14401
C250 14401
C251 14401
C252 14401
C257 14401
C258 14401
C260 14401
C261 14401
C262 14401
C263 14A504
C267 14401
C268 F 14A265
C268 M 14A509
C269 14401
C270 F 14A265
C270 M 14401
C271 14401
C273 14401
C274 14401
C275 14401
C276 14401
C278 14401
C279 14401
C280 14401
C282 PIA
C283 PIA
C292 14401
C293 13A726
C294 13A726
C295 13A726
C296 14401
C298 14401
C299 F 17K745
C299 M 14A504
C300 F 14334
C300 M 14A504
C302 14A504
C305 14B084
C306 14B084
C310 14086
C311 14086
C312 14B084
C313 F 14A504
C313 M 14B084
C314 F 14A504
C314 M 14B084
C315 F 14335
C315 M 14A504
C317 14B084
C318 F 13A625
C318 M 14335
C326 14A504
C327 14A504
C328 14B095
C329 12A581
C330 12A581
C402 14405
C404 14405
C405 F 14405
C405 M 13A409
C406 F 14405
C406 M 13A409
C407 F 13A576
C407 M 14405
C417 F PIA
C417 M 13A576
C418 F 14405
C418 M 14086
C424 F 13A576
C424 M 14405
C428 14086
C429 14086
C431 13A409
C432 13A409
C433 13A409
C434 13A409
C435 14405
C436 14405
C441 14405
C500 14A509
C501 14A509
C502 14A509
C503 14A509
C504 14A509
C507 14A509
C508 14A509
C509 F 14A265
C509 M 14A509
C550 14A509
C600 14A265
C601 14A265
C602 14A265
C603 14A265
C606 14A265
C607 14A265
C608 14A265
C905 14334
C906 14334
C907 13A625
C908 13A625
C911 17K745
C912 17K745
C913 17K745
C914 17K745
C1005 12A581
C1006 12A581
C1007 9D930
C1008 9D930
C1012 15525
C1017 9D930
C1019 12A581
C1020 15525
C1021 12A581
C1022 9D930
C1023 9D930
C1024 9D930
C1025 5.0L 9D930
C1025 5.8L 12A690
C1028 5.0L 9D930
C1028 5.8L 15525
C1030 12A581
C1031 12A581
C1032 12A581
C1033 12A581
C1034 12A581
C1035 15A702
C1040 PIA
C1048 15525
C1049 15525
C1052 12A581
C1053 12A581
C1054 12A581
C1055 12A581
C1069 15525
Connector Locations & Number of Terminals:
C124 At RH front wheel, on right front wheel 4WABS sensor (C1), Terminal: 02
C126 LH side of engine compartment, on A/C high pressure cut out switch (A4), Terminal: 04, Color: BK
C129 RH rear of engine compartment, on heater blower plenum, Terminal: 02
C130 Top center of safety wall, on mass air flow (MAF) sensor (D10),Terminal: 04 Mass Air Flow (MAF) Sensor
C131 RH front of engine compartment, on ambient temperature sensor (F7),Terminal: 0
C135 Lower LH rear of engine, on engine oil pressure switch (A3), Terminal: 01, Color: BK
C139 RH front of engine compartment, behind battery (C1),Terminal: 04, Color: BK
C150 Top LH front of engine, on coolant temperature sensor (F9),Terminal: 01
C151 Top LH side of safety wall, on windshield wiper motor (A5),Terminal: 06, Color: GY Windshield Wiper Motor
C152 LH side of engine compartment, near brake master cylinder (A10), Terminal: 10, Color: GY Speed Control Servo/Amplifier Assembly
C153 RH front of engine, on generator/voltage regulator (F5),Terminal: 01
C154 RH front of engine, on generator/voltage regulator (F5), Terminal: 03, Color: BK
C161, Automatic, Front of transfer case, near 4x4 hi/low indicator switch (F4),Terminal: 02, Color: BK
C161, Manual Front of transfer case, near 4x4 hi/low indicator switch (B10), Terminal: 02, Color: BK
C162 RH rear of engine compartment, on A/C clutch cycling pressure switch (A2), Terminal: 03, Color: GY
C163 LH front of engine, on A/C clutch field coil (F5), Terminal: 02, Color: BK
C164 Top center front of engine, on intake air temperature (IAT)sensor (D10),Terminal: 02, Color: BK
C166 Top LH side of transmission, on backup lamp switch (B10) Terminal: 02 Color: BK
C168 RH side of safety wall, near blower motor (B1) Terminal: 02 Color: BK
C169 RH side of safety wall, on blower motor resistor (A1) Terminal: 04 Color: W
C170 LH rear of engine compartment, on brake fluid level switch (A8) Terminal: 03 Color: GY
C177, Daytime Running Lamps (DRL) Module, with DRL Front LH side of lower radiator support, on daytime running lamps (DRL) Module (E10) Terminal: 08 Color: BK
C177, without DRL Front LH side of lower radiator support, on daytime running lamps (DRL) jumper (F9) Terminal: 08 Color: BK
C178 Distributor Top center front of engine, near distributor (F8) Terminal: 08
C180 Top LH side of engine, on EGR control solenoid (A6) Terminal: 02 Color: BK
C182 Top RH front of engine, on delta pressure feedback EGR (DPFE) Sensor (D1) Terminal: 03 Color: BK
C183 Center front of engine, on engine coolant temperature (ECT) sensor (F4) Terminal: 02 Color: BR
C185, 5.0L Powertrain Control Module (PCM) LH side of safety wall, on powertrain control module (PCM) (C10) Terminal: 104 Color: GY
C185, 5.8L Powertrain Control Module (PCM) LH side of safety wall, on powertrain control module (PCM) (C10) Terminal: 104 Color: GY
C190 Top RH front of engine, on fuel injector #1 (F6) Terminal: 02 Color: BK
C191 Top RH side of engine, on fuel injector #2 (F6) Terminal: 02 Color: BK
C192 Top RH side of engine, on fuel injector #3 (F6) Terminal: 02 Color: BK
C193 Top RH rear of engine, on fuel injector #4 (F6) Terminal: 02 Color: BK
C194 Top LH front of engine, on fuel injector #5 (F6) Terminal: 02 Color: BK
C195 Top LH side of engine, on fuel injector #6 (F6) Terminal: 02 Color: BK
C196 Top LH side of engine, on fuel injector #7 (F6) Terminal: 02 Color: B
C197 Top LH rear of engine, on fuel injector #8 (F6) Terminal: 02 Color: BK
C200 Behind LH cowl panel (A2) Terminal: 08 Color: GY In-Line
C201 Data Link Connector (DLC) Behind lower RH side of I/P, below glove compartment (E1) Terminal: 16
C202 LH rear of engine compartment, in safety wall (A8) Terminal: 7 In-Line
C203 Behind RH cowl panel (A5) Terminal: 06 Color: BR
C204 Behind lower center of I/P, near RH side of ashtray assembly (F3) Terminal: 04 Color: BK
C205 LH rear of engine compartment, in safety wall (A7) Terminal: 24 In-Line
C206 At base of LH "A" pillar (A1) Terminal: 10 In-Line
C207 Behind lower LH side of I/P, on fuse panel (D10) Terminal: 01 Color: W
C209 Behind RH cowl panel (F8) Terminal: 16 Color: BK In-Line
C210 Behind lower center of I/P, on trailer electronic brake control unit (F2) Terminal: 06 Color: G In-Line
C211 Radio, with Premium Sound, Behind center of I/P, on radio (A4) Terminal: 08
C212 Premium Sound Amplifier, Behind center of I/P, on premium sound amplifier (A5) Terminal: 14
C213 Behind RH cowl panel (F7) Terminal: 08 In-Line
C214 Behind LH cowl panel (E1) Terminal: 08 Color: G In-Line
C217 Air Bag Diagnostic Monitor, Behind LH side of I/P, on air bag diagnostic monitor (F3) Terminal: 12 Color: GY
C218 Air Bag Diagnostic Monitor, Behind LH side of I/P, on air bag diagnostic monitor (F3) Terminal: 12 Color: BK
C219 Speed Control/Horn Switch Assembly, Lower steering column, to speed control/horn switch assembly (F8) Terminal: 10 Color: GY
C220 Transfer Case Assembly, Below center of vehicle, near transfer case assembly (F5) Terminal: 10 Color: BK
C221 Electronic Shift Control Module, Behind RH cowl panel, on electronic shift control module (F6) Terminal: 08 Color: W
C222 Electronic Shift Control Module, Behind RH cowl panel, near electronic shift control module (F6) Terminal: 08 Color: GY
C223 Electronic Shift Control Module, Behind RH cowl panel, on electronic shift control module (F6) Terminal: 05 Color: BR
C224 Wiper Control Module, Behind RH side of I/P, on wiper control module (C1) Terminal: 14
C226 In steering column, on clockspring assembly (A7) Terminal: 03
C227 Top of steering column, on steering column air bag (A8) Terminal: 03
C228 Behind RH cowl panel (A5) Terminal: 08 Color: GY In-Line
C229 Behind LH cowl panel (C1) Terminal: 16 Color: GY In-Line
C230 Multi-Function Switch, Top of steering column, on multi-function switch (B10) Terminal: 07
C231 Multi-Function Switch, Top of steering column, on multi-function switch (B10) Terminal: 1o Color: GY
C232 Behind lower RH side of I/P, below glove compartment (E1) Terminal: 01 Color: BR
C234 Behind lower center of I/P, on auxiliary power socket (F6) Terminal: 01 Color: BR
C236 In steering column, on shift lock actuator (A6) Terminal: 03
C240 Remote/Keyless Entry Module, Behind LH side of I/P, on remote keyless entry module (B10)Terminal: 13
C241 Remote/Keyless Entry Module, Behind LH side of I/P, on remote keyless entry module (B10) Terminal: 16
C242 Remote/Keyless Entry Module, Behind LH side of I/P, on remote keyless entry module (B10) Terminal: 1
C243 Behind LH side of I/P, on RKE program connector Terminal: 02
C250 Instrument Cluster, Behind top LH side of I/P, on instrument cluster (A6) Terminal: 14 Color: BR
C251 Instrument Cluster, Behind top LH side of I/P, on instrument cluster (A9) Terminal: 14 Color: GY
C252 Programmable Speedometer/Odometer Module (PSOM), Behind top LH side of I/P, on PSOM (A7) Terminal: 12 Color: B
C257 Radio Jumper, with Premium Sound, Behind I/P, near radio (A4) Terminal: 08 Color: BK
C258 Radio Jumper, with Premium Sound, Behind I/P, near radio (A4) Terminal: 08 Color: BK
C260 Behind center of I/P, on blower motor switch (A4) Terminal: 04 Color: GY
C261 Clutch Pedal Position (CPP) Switch, Automatic, Behind LH side of I/P, on clutch pedal position switch jumper (F4) Terminal: 06 Color: G
C261, Manual, Behind LH side of I/P, on clutch pedal position switch (F4) Terminal: 06 Color: G
C262 In front of RH front door jamb, on right courtesy lamp switch (F4) Terminal: 03 Color: N
C263 In lower rear of LH front door jamb, on left front courtesy lamp switch (F2) Terminal: 03 Color: GY
C267 BW 1356 Electronic Shift Control Switch, Behind top LH side of I/P, on electronic shift control switch (A6) Terminal: 08 Color: GY
C268 Behind RH cowl panel (A5) Terminal: 04
C269 Ignition Switch, Top RH side of steering column, on ignition switch Terminal: 15
C270 Top front of RH front door (A7) Terminal: 03
C271 Behind RH cowl panel, on inertia fuel shutoff (A4) Terminal: 03 Color: GY
C273 Main Light Switch, Behind top LH side of I/P, on main light switch (C10) Terminal: 09 Color: GY
C274 Master Tailgate Window Switch, Behind top LH side of I/P, on master tailgate window switch (C10)Terminal: 05 Color: G
C275 Top of steering column, near transmission control switch (C10) Terminal: 03
C276 Behind LH side of I/P, on park brake switch (F8) Terminal: 01 Color: BK
C278 Rear Window Defrost Control, ehind top LH side of I/P, on rear window defrost control Terminal: 05 Color: N
C279 Behind LH side of I/P, on brake ON/OFF (BOO) switch (F7) Terminal: 02 Color: BK
C280 Warning Chime Module, Behind lower center of I/P, on warning chime module (F6) Terminal: 07 Color: GY
C282 Radio, with Premium Sound, Behind center of I/P, on radio (A4) C283 Premium Sound Amplifie, Terminal: 08
C283 Premium Sound Amplifier, Behind center of I/P, on premium sound amplifier (A5) Terminal: 08
C292 Behind RH side of I/P, on glove compartment lamp (B1) Terminal: 02 Color: BR
C293 Behind lower center of I/P, on ashtray illumination (F5) Terminal: 02 Color: BK
C294 Behind lower center of I/P, on cigar lighter (F4) Terminal: 01
C295 Below lower center of I/P, on cigar lighter (F4) Terminal: 01 Color: B
C296, with A/C Behind center of I/P, on A/C-heater control assembly (A2) Terminal: 04 Color: W
C296, without A/C Behind center of I/P, on heater control assembly (A2) Terminal: 04 Color: W
C298 Behind center of I/P, on heater control illumination (A4) Terminal: 02 Color: BK
C299 At base of LH "A" pillar (A1) Terminal: 08 In-Line
C300 At base of LH "B" pillar (A2)Terminal: 04 Color: GY
C302 Below RH side of LH front seat, to seat belt switch (A3) Terminal: 02 Color: GY
C305 Under LH side of LH front seat, to left power lumbar switch (F8) Terminal: 02 Color: GY
C306 Under RH side of RH front seat, to right power lumbar switch (D1) Terminal: 02 Color: GY
C310 LH side of tailgate, near rear window, on rear window defrost grid (A7Terminal: 01 Color: B
C311 Center of tailgate, near rear window, on rear window defrost grid (A7) Terminal: 01 Color: BK
C312 Under front of LH seat, on left power lumbar compressor motor (F6) Terminal: 02 Color: BK
C313 Below LH front seat (C9) Terminal: 02 Color: GY
C314 Below RH front seat (A3) Terminal: 02 Color: GY
C315 At base of LH "B" pillar (F3) Terminal: 04 Color: BR
C317 Under front of RH front seat, on right power lumbar compressor motor (F3) Terminal: 02 Color: BK
C318 LH rear of cargo area, near center of "D" pillar (F6) Terminal: 06 Color: B In-Line
C326 LH side of cargo area, on left rear speaker (A3) Terminal: 02 Color: GY
C327 RH side of cargo area, on right rear speaker (B10) Terminal: 02 Color: GY
C328 Air Bag Safing Sensor, Mounted on RH side of frame rail, on safing sensor (C10) Terminal: 05
C329 Mounted on LH side of frame rail, to left primary crash sensor (F9) Terminal: 04
C330 Mounted near RH side of cowl panel, to right primary crash sensor (F3) Terminal: 04
C402 Under driver, on LH frame rail on acceleration sensor (E1) Terminal: 03
C404 VSS On rear axle sensor (A7) Terminal: 02
C405 Under LH rear of vehicle, on frame rail, near fuel tank (D10) Terminal: 04 Color: GY
C406 Under LH rear of vehicle, near rear crossmember (F7) Terminal: 04 Color: GY
C407 Under center rear of vehicle, near rear crossmember (E10) Terminal: 04 Color: BK
C417 Under vehicle, near rear crossmember (D10) Terminal: 07 In-Line
C418 Under LH rear of vehicle, near rear lamp assembly (F7) Terminal: 04 Color: N
C424 Under center rear of vehicle, near rear crossmember (D10) Terminal: 04 Color: GY
C428 In LH side of tailgate, on tailgate latch switch (E10) Terminal: 02 Color: B
C429 In lower center of tailgate, to tailgate power window motor (D10) Terminal: 02 Color: GY
C431 LH rear of vehicle, on left rear park/stop/turn lamp (F8) Terminal: 03 Color: BK
C432 RH rear of vehicle, on right rear park/stop/turn lamp (C10) Terminal: 03 Color: B
C433 LH rear of vehicle, on left backup lamp (F6) Terminal: 02 Color: BK
C434 RH rear of vehicle, on right backup lamp (D10) Terminal: 02 Color: BK
C435 Center rear of vehicle, on license lamp (E10) Terminal: 02 Color: BK
C436 Center rear of vehicle, on license lamp (E10) Terminal: 02 Color: BK
C441 Top RH side of fuel tank, on fuel pump module (C10) Terminal: 04 Color: BK
C500 In lower front LH front door, to left front window motor (B1) Terminal: 02 Color: GY
C501 Left Power Mirror, Top front of LH door, on left power mirror (C1) Terminal: 08
C502 In rear of LH front door, on left door lock motor (D1) Terminal: 02 Color: N
C503 Window/Door Lock Control Switch (Master/Left), with Remote/Keyless Entry, In center of LH door, on window/door lock control switch (Master/Left) (C1) Terminal: 15
C503 Window/Door Lock Control Switch (Master/Left), without Remote/Keyless Entry, In center of LH door, on window/door lock control switch (Master/Left) (C1) Terminal: 15
C504 In lower rear of LH door, on left door courtesy lamp (D1) Terminal: 02 Color: B
C507 In top front of LH door, on left door speaker (A1) Terminal: 02 Color: G
C508 In front of LH door, to left power mirror (C1) Terminal: 04
C509 Behind RH cowl panel (A5) Terminal: 03
C550 Power Mirror Switch, In center of LH door, near power mirror switch (C1) Terminal: 08 Color: GY
C600 In lower front of RH door, to right front window motor (F5) Terminal: 02 Color: N
C601 Right Power Mirror, Top front of RH front door, to right power mirror (A6) Terminal: 08
C602 In rear of RH door, on right door lock motor (A10) Terminal: 02 Color: N
C603 Right Window And Door Lock Control Switch, with Remote/Keyless Entry, In center of RH door, on right window and door lock control switch (A9) Terminal: 10
C603 Right Window And Door Lock Control Switch, without Remote/Keyless Entry, In center of RH door, on right window and door lock control switch (A9) Terminal: 10
C606 In lower rear of RH door, on right door courtesy lamp (A10) Terminal: 02 Color: BK
C607 In top front of RH door, on right door speaker (A6) Terminal: 02 Color: GY
C608 In front of RH door, to right power mirror (A6) Terminal: 04 Color: N
C905 Center of roof, on map lamps (A5) Terminal: 01 Color: G
C906 Center of roof, on dome lamp (A5) Terminal: 01 Color: G
C907 Top center rear of vehicle, on outside cargo/high-mount stop lamp (B10) Terminal: 03 Color: G
C908 Center of rear window header, near inside cargo lamp (B10) Terminal: 03 Color: GY
C911 In driver's side visor, on left vanity mirror lamp (A3)Terminal: 01
C912 In passenger's side visor, on right vanity mirror lamp (A5) Terminal: 01
C913 In center of windshield header, on day/night mirror (A4) Terminal: 03
C914 Compass/Outside Temperature Module, In center of windshield header, on overhead console (A4) Terminal: 10
C1005 Front RH side of lower radiator support, on low pitch horn (F3) Terminal: 01 Color: BK
C1006 Front RH side of lower radiator support, on high pitch horn (F2) Terminal: 01 Color: BK
C1007 Top RH front of engine, on idle air control valve (F6) Terminal: 02 Color: BK
C1008 LH rear of engine, on ignition coil (A7) Terminal: 03
C1012 Transmission Range (TR) Sensor, with 4R70W Transmission, Below center of vehicle, LH side of transmission, on transmission range (TR) sensor (F2) Terminal: 08 Color: BK
C1012 Transmission Range (TR) Sensor, with E4OD Transmission, Below center of vehicle, LH side of transmission, on transmission range (TR) sensor (F2) Terminal: 08 Color: BK
C1017 LH side of engine, near radio capacitor (A8) Terminal (none specified)
C1019 LH rear of engine compartment, taped to harness, near ignition control module (ICM), on SPOUT check connector (C10) Terminal: 02 Color: BK
C1020 LH rear of transmission, on output shaft speed sensor (F3) Terminal: 02
C1021 Ignition Control Module (ICM), LH rear of engine compartment, on ignition control module (ICM) (B10) Terminal: 06 Color BK
C1022 Top LH rear of engine, on secondary air injection bypass (AIRB) solenoid (A5) Terminal: 02 Color: BK
C1023 Top LH rear of engine, on secondary air injection diverter (AIRD) solenoid (A5) Terminal: 02 Color: GY
C1024 Top RH front of engine, near throttle position sensor (TPS) (F3) Terminal: 03 Color: BK
C1025 Lower RH rear of engine, near starter on heated oxygen sensor (HO2S) #11 (A2) Terminal: 04
C1028 LH rear of engine, to heated oxygen sensor (HO2S) #21 (A2) Terminal: 04
C1030 Lower LH front of engine compartment, on windshield washer pump motor (D10) Terminal: 02 Color: BK
C1031 LH front of vehicle, on left front park/turn lamp (F7) Terminal: 03 Color: BK
C1032 RH front of vehicle, on right front park/turn lamp (F4) Terminal: 03 Color: BK
C1033 LH front of vehicle, on left headlamp (F8) Terminal: 03 Color: BK
C1034 RH front of vehicle, on right headlamp (F3) Terminal: 03 Color: BK
C1035 LH underside of engine compartment hood, on engine compartment lamp (A7) Terminal: 02 Color: GY
C1048 E4OD Transmission, RH front of vehicle, RH side of E4OD transmission (A2) Terminal: 12 Color: GY
C1049 4R70W Transmission, Below center of vehicle, RH side of 4R70W transmission (A2) Terminal: 10
C1052 RH front of vehicle, on right front side marker lamp (E1) Terminal: 02 Color: BK
C1053 RH front of vehicle, on right front side marker lamp (E1) Terminal: 02 Color: BK
C1054 LH front of vehicle, on left front side marker lamp (E10) Terminal: 02 Color: BK
C1055 LH front of vehicle, on left front side marker lamp (E10) Terminal: 02 Color: BK
C1069 Under vehicle, behind engine, near catalytic converter Terminal: 04
SPLICE Locations in a 96, from 96 FORD EVTM;
(note that all are shown, I did not skip any)
S100 Engine control sensor harness, near T/O to right front park/turn lamp
S101 Engine control sensor harness, near T/O to powertrain control module (PCM)
S102 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S103 Engine control sensor harness, near T/O to left front park/turn lamp
S104 Engine control sensor harness, near T/O to powertrain control module (PCM
S105 Engine control sensor harness, near T/O to engine compartment fuse box
S106 Engine control sensor harness, near T/O to G100
S107 Engine control sensor harness, near T/O to G101
S110 Engine control sensor harness, near T/O to right front park/turn lamp
S115 Engine control sensor harness, near T/O to left headlamp
S116 Engine control sensor harness, near T/O to C103
S119 Engine control sensor harness, near trailer relay box
S120 Engine control sensor harness, near T/O to C202
S121 Engine control sensor harness, near T/O to LH headlamp
S122 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S123 Engine control sensor harness, near T/O to left headlamp
S124 Backup lamp switch to rear lamp feed harness, in T/O to 4R70W transmission
S125 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S126 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S127 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S134 Backup lamp switch to rear lamp feed harness, near T/O to transmission range (TR) sensor
S135 Engine control sensor harness, near T/O to C101
S136 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S137 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S139 Engine control sensor harness, near T/O to powertrain control module (PCM)
S145 Engine control sensor harness, near T/O to powertrain control module (PCM)
S146 Backup lamp switch to rear lamp feed harness, in T/O to transmission range (TR) sensor
S148 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S149 Fuel charge harness, near T/O to air charge temperature (ACT) solenoid
S150 Engine control sensor harness, near T/O to 4WABS hydraulic unit
S151 Fuel charge harness, near T/O to fuel injector #3
S152 Heater switch to blower motor harness, near T/O to blower motor
S153 Heater switch to blower motor harness, near T/O to blower motor
S154 Engine control sensor harness, near T/O to left headlamp
S155 Engine control sensor harness, near T/O to G100
S156 Engine control sensor harness, near T/O to left front park/turn lamp
S159 Fuel charge harness, near T/O to fuel injector #8
S160 Fuel charge harness, near T/O to fuel injector #5
S161 Fuel charge harness, near T/O to fuel injector #4
S163 Engine control sensor harness, near T/O to powertrain control module (PCM)
S168 Backup lamp switch harness, in T/O to backup lamp switch
S169 Back lamp switch harness, in T/O to transmission
S170 Engine control sensor harness, near T/O to C123
S171 Engine control sensor harness, near T/O to powertrain control module (PCM)
S174 Engine control sensor harness, near T/O to brake warning resistor/diode assembly
S199 Fuel charge harness, near T/O to ignition coil
S200 Seat belt retractor switch RH harness, near T/O to G201
S202 Main harness, near T/O to C261
S203 Main harness, near T/O to enable PSOM programming connector C232
S204 Main harness, near T/O to multi-function switch
S205 Main harness, near T/O to C243
S206 Main harness, near T/O to fuse panel
S208 Main harness, near T/O remote/keyless entry module
S209 Main harness, near T/O to fuse panel
S210 Main harness, in T/O to G200
S211 Main harness, near T/O to fuse panel
S212 Main harness, in T/O to remote keyless entry module
S213 Main harness, near T/O to warning chime module
S214 Main harness, near T/O to warning chime module
S215 Main harness, near T/O to C251
S216 Main harness, in T/O to G200
S217 Main harness, near T/O to fuse panel
S218 Main harness, near T/O to radio
S219 Rear lamps harness, near T/O to C205
S220 Main harness, near T/O to C202
S222 Seat belt retractor switch RH harness, near T/O to C300
S224 Main harness, in T/O to clutch pedal position switch or jumper
S225 Rear lamps harness, near T/O to C205
S226 Window regulator left front door harness, near T/O to C214
S227 Main harness, in T/O to air bag diagnostic monitor
S229 Main harness, in T/O to rear of blower motor switch
S231 Main harness, near T/O to C202
S233 Radio amp harness, near premium sound amplifier
S234 Main harness, near T/O to C202
S236 Main harness, near T/O to fuse panel
S237 Main harness, near T/O to brake on/off switch
S238 Main harness, near T/O to wiper control module
S240 Main harness, near T/O to clutch pedal position switch or jumper
S242 Main harness, near T/O to fuse panel
S244 Main harness, near T/O to C210
S245 Main harness, near T/O to clutch pedal position switch or jumper
S246 Main harness, near T/O to speed control amplifier
S251 Seat belt retractor switch harness, near T/O to C300
S270 Main harness, near T/O to C202
S271 Main harness, near T/O to C202
S299 Main harness, near T/O to right front courtesy lamp switch
S301 Window regulator harness, near T/O to door speaker
S302 Window regulator harness, near T/O to door speaker
S303 Main harness, near T/O to enable PSOM programming connector C232
S304 Window regulator right front door harness, near T/O to C603
S305 Seat belt retractor switch RH harness, near T/O to C300
S306 Main harness, near T/O to trailer brake controller
S308 Rear high mount lamp harness, near T/O to outside cargo/high mount stop lamp
S315 Main harness, near T/O to keyless entry module
S316 Seat belt retractor switch harness, near T/O to seat belt retractor switch
S400 Rear lamps harness, near T/O to fuel pump module
S401 Rear lamps harness, near T/O to license lamps
S405 Left lamp connector harness, near T/O to left backup lamp
S406 Right rear lamp connector harness, near T/O to right backup lamp
S417 Rear lamps harness, near T/O to license lamps
S423 Rear window regulator control harness, near T/O to tailgate window switch
S424 Rear lamps harness, near T/O to license lamps
S500 Window regulator left front door harness, near T/O to master window control switch
S501 Window regulator left front door harness, near T/O to C214
S502 Window regulator left front door harness, near T/O to C50
S600 Window regulator right front door harness, near T/O to C600
S601 Window regulator right front door harness, near T/O to C600
S602 Window regulator right front door harness, near T/O to right window control switch
S900 Rear view inside mirror harness, in windshield header
S901 Rear view inside mirror harness, in windshield header
S902 Rear view inside mirror harness, in windshield header
96 5.8 was not built with Air Injection (AIR), Secondary Air Injection; Pump (Smog Pump), Thermactor Air Bypass (TAB) & Thermactor Air Diverter (TAD) Solenoids; Diverter, Check & Bypass Valves, Cross-Over Tube, etc.
But, the 96 5.0 was built with secondary air. So the 5.0 PCM will pop seconday air codes
Thanks for your help Travis. The previous owner took the engine wiring harness when he pulled the 5.0 motor. He also cut the y pipe ?. I bought a 94 F250 with an E4OD A/T and am trying to use the speed density harness. I understand you are correct but so far I've only found two wires that were missing at the 12A581 connector. The red 12V wire that powers the injectors was not there. There is also a missing brown wire but I haven't traced it out yet. The only code I'm getting is for the O2 sensor on bank 2. The diagram Miesk provided shows that i should have three O2 sensors. Bank 1 and bank 2 should be where the manifold meets the y pipe. The third sensor should be between the two cats. The wiring diagram shows the bank one and back two O2 sensor wiring coming off the fender on each side from the main loom not the engine harness. I do not have those wiring connections in my bronco. I only have the single wiring connector that matches the picture that Miesk provided that shows the sensor at the bridge between the two y pipes just before the cat. My computer is reading that plug as bank one. I'm thinking I'll share that signal with bank two to satisfy the computer and see if it fixed the problem or if a new code pops up. So far all of the engine components appear to be reading out correctly on my diagnostic computer. Honestly I'm enjoying the challenge of this swap. In my past restorations I've mostly replaced with the factory motors. It's good to work the brain!
Thanks Miesk, that's the mother lode of wiring data! I'll need some time to print and trace through it ?
Discussion Starter #11
I found the C103M connector diagram online. I found the 95 but it looks identical to the 96. The 12A581 PCM side has Sixteen pins labeled as follows:
1 = 298 (P/O)
2 = 140 (BK/PK)
3 = 32 (R/LB)
4 = 32 (R/LB)
5 = 199 (LB/Y)
6 = 359 (GY/R)
7 = 463 (R/W)
8 = 923 (O/BK)
9 = 480 (P/Y)
10 = 315 (P/O)
11 = 766 (BK/LG)
12 = 970 (DG/W)
13 = 57 (BK)
14 = 924 (BR/O)
15 = 210 (LB)
The C103F appears to be the mirror image for the motor side. Does anyone have a wiring list that labels what each wire is for or each pin whichever is easier? I want to try and get ahead of the concerns Travis mentioned above. Not sure if they would be different from 95 to 96 but my 96 is MAF.
aka: kemicalburns
a 95 MAF is OBD-I, the 96 is OBD-II.
95 MAF uses 1 o2 sensor
96 OBD-II MAF uses 3 o2 sensors.
the engine harness you pulled with the 5.8 is speed density, so the injector wiring is going to be wrong not to mention the pin out. it would also require the correct speed density computer.
next issue is the transmission is going to want to see a 96 computer so in my opinion you are fighting a considerable wiring battle here. Are you unable to locate the proper 96 OBD-II wiring harness and computer from a wrecking yard? doesnt really matter if its a 5.0 or 5.8.
Discussion Starter #13
Thanks again Travis. I have the original 96 5.0 computer that came with the truck. I was told not to use it because it has different calibration and would throw the air fuel ratio off. Is that wrong?
I can put it back in and see if the O2 sensor alarm clears. Engine sure ran nice on the 5.8 computer when I took over idle control and before it warmed up
aka: kemicalburns
96 compute should only be used with OBD-II harness and MAF. it should run the 5.8 just fine but again your not going this route.
95 5.8L MAF XLT, Hedman Shorties/MF SS Y & Muff, E4OD, Man hubs, KYB Quads, 31x10.5x15, 301K miles
Gee my 95 5.8L MAF OBD-I has 2 O2 sensors, one on each leg of the Y-Pipe Before the Cat!!!!
Discussion Starter #16
Travis I'm probably not communicating clearly so let me try to clarify and get on the same page with you. Both my computers are 96 MAF. The 5.0 computer came with the truck. I bought the 5.8 from Cardone and the specs are further up the thread.
I think you're recommending I get another engine harness versus going down the current path. I hear that and understand the wisdom in your recommendation. What I was trying to explain earlier is that the O2 sensors aren't part of the engine harness. They come off the PCM harness. The PCM harness and all other wiring in the truck is original and unmolested. In my case I've only located the bank one O2 sensor. I've not located the bank two sensor wiring nor the sensor three wiring. I've been all over the truck and plan to open some of the Shields to see if the wires are there and just not the plugs. Miesk attached everything I need to trace them down.
My current goal is to satisfy the O2 sensor code while enjoying some quality garage time and some cold beers. If I'm lucky maybe I'll only need two sensors like Steveo! Once I get past that code I'll see what else pops up. I may need to get another harness as you suggest. If I have the wiring diagram to identify the pinout on the C103 connector I should be able to verify the differences between my 5.8 harness and the 5.0 harness. I appreciate everyone's help. I'm having fun here
Discussion Starter #17
Miesk my pinout appears to match what you sent on the PCM connector diagram and list but the color codes called out for the wires do not. I triple checked to ensure I had the correct orientation.
Was there any variations that you're aware of? I'm going to add some jumpers to test out but thought I should ask the question.
Discussion Starter #18
Update. When I spliced the O2 sensor wires together I got an additional code. I originally had P0155 O2 sensor heater circuit bank 2 sensor 1 and P0385 crank shaft position sensor B circuit.
When I spliced the signal from bank 1 into bank 2 (since my vehicle wiring harness is not equipped with the bank two plug) I now have a new code P0135 O2 sensor heater circuit bank 1 sensor 1.
I haven't started diagnostics yet but I'm guessing the heat circuit on bank two must have a short that I've now introduced into bank one. Anyone think that it could be something else or the best way to eliminate a variable?
Also I'm not overly concerned about P0385 because my vehicle isn't equipped with the sensor. Guessing that's just telling me the circuit is open. Other thread seemed to indicate it won't affect the engine but let me know if you disagree.
Thanks so much!
1 - 18 of 18 Posts
