i saw a truck on here that had o5 axle swap on here one time and had some questions for him but cant find him. anyway, i found a set of o6 axles w/373 gears for my 95 and had some questions about the install. i also need some stock parts since these axles dont have any suspension.
Engineer
I think JoeBob has superduty axles on his centurian
Engineer
I'd rather have a unit bearing 60 than a broken 44
There is nothing wrong with unit bearings. They aren't as good as standard bearings, but internet folly has greatly exaggerated the negatives.
On the scale, I'd rather have that 60 than an earlier BJ 60; after 05, they got 35 spline outers :D
Wrenching for a Livin'
my only concern would be is there room for spring perches or C's(or similar) depending on what kind of suspension you want to run. I think the diff on those newer ones is offset REALLY far.
oh, there is a conversion to go back to standard bearings, its pricey
How do the radius arms hook up on these? I've never actually looked at the mounts :toothless
It'd probably be easy to fab up some nice radius arms around the stock SuperDuty mounts...
