1 - 11 of 11 Posts
My thermometer occasionally goes all the way to the H when I am driving it on the road. I can get it to lower some when I turn on the heater; but turning the car off works a lot better. I just recently had my oil changed and coolant topped off to see if that helped. Just wondering what the problem could be? Thanks.
Plugged radiator?Make sure the themostat is operating properly,if it is then the radiator may be plugged.Had a plugged radiator on my daughters car,it acted exactly as you are describing.
Sway Is My Fan Club.
Turning it off makes the temp go down? That's odd, usually when you shut it off, the temp goes up [before it starts to cool] because the coolant is no longer circulating and being cooled by air. Hmm..
Try changing the t-stat like the boys said. :thumbup
What type of Bronco?
What type of Bronco do you have?
Also do you have an engine fan that is supposed to be pulling air flow through the radiator.
Boy, I had a hell of a problem with overheating before I completely removed my engine fan (gives me more HP now also), and installed 2 electric fans.
Here is what it used to look like under there (took me several weeks of searching these forums, and allot of help from other FSB members to learn that I had the incorrect fan shroud installed. Came w/Bronco)
So I completeley got rid of fan shroud and engine fan, removed radiator, flushed it,etc....and installed (2) 10" Hayden Rapid Cool Electrical Fans. Part # 3560. They will be run by 1 Hayden PreSet Temp Control switch. Part # 3562
Now it looks like this under there, and NEVER get's above 3/4 hot (on my gage) down here in South Texas. We go all over the Sand Dunes on the beach during the weekends and driving all over our brush heavy ranch during the week and have yet for it to overheat. I got my money's worth.
Discussion Starter · #8 ·
I will take a look at the thermostat, I just replaced the radiator not too long ago. Thanks for the advice and I will let you guys know...
Discussion Starter · #9 ·
Thanks for the write up...if the t'stat doesnt solve my prob I will look into this.
Call Me Ace
mine would overheat if i sat in traffic for more than 5 minutes.
i had a bunch of build-up and scale in the lower intake manifold- i found out while i was replacing my headgaskets.
its a pain in the ass- but if the t-stat doesnt fix it- and your radiator isnt plugged... keep it in the "maybe"s
ace
Take care of it soon.. I've been having an issue with our chevy overheating and well today the heagasket finally blew all the way... It's not an easy fix for someone who doesn't know much about motors.. Good look to you.
1 - 11 of 11 Posts
