1 - 3 of 3 Posts
Greetings! Glad to be a part of an awesome forum. Just purchased my 1990 Bronco with a 5.0 engine and a couple miles in the bank. Planning on taking onto plenty of dirt with my mountain bike. Currently putting some effort into keeping it alive such as replacing the belt, changing out the oil, replacing the air filter, and replacing both head lights. My first question would have to be what would be the best brake fluid recommended as well as power steering fluid?
Charlie don't surf..
'92 Ford Bronco XLT
welcome to the site..
for questions, head on over to the newbie section and post up there..
as for brake fluid, I use whatever is the cheapest..that last I bought was a gallon container from the zone...
I do the same for the powersteering fluid, or you can run ATF..
welcome
the bronco should bring you to some sweet mountain biking trails for sure
on brake fluid,buy only enough for the job on hand,once the container is opened,it will start to absorb moisture and not be good to put into the truck if it sits a while
always keep a new un opened factory sealed container on hand just in case
1 - 3 of 3 Posts
