Ever since my son put 4" lift on his Bronco the rear driveshaft looks like in a bit of a bind. I saw a ad in Bronco Driver for Tom Woods driveshafts. They have what looks like a off set u-joint the "Super Flex" Said to gain 10 degrees of flexibility. Any one using one of these and what do you think of it ?? Thanks
With only a 4" lift you should not be having any driveshaft angle or binding problems. Post some pics of it so we can see.
no binding should be back there.
also those offset u-joints are not made for high speed driving, only slow off road use
Im running one of those on the front shaft near the tcase on my 78 F150 6" lift. On the front its not a problem cause im rarely going over 25mph in 4wd. On the rear it would vibrate like mad over 25mph. Definately fixed the bind though.
No bind on the rear shaft on my 78 beater with 4" lift.
Smooth as glass @ highway speeds with the 36 swamper radials it has on it now, no vibes of any kind.
