1 - 3 of 3 Posts
Hey everyone, i installed a electric temp and electric oil gauge on on piller, connecting to sensors with factory gauges also still connected to same sensors, but dash gauges not working now (just oil and temp)... is this normal or can you only have one gauge per sensor?
Also when key on the new pillar temp gauge reads 180 and oil reads 25 without the truck even being ran? any advice would be great thanks
Sounds like you've got some wires crossed. If I'm right in assuming you used the correct parts and just simply "spliced" into the original wiring then both sets of gauges should still work. That is of course, assuming they worked before. I would start over from the beginning making sure you wired them in correct. Use a power probe and/or a test light to ensure you're splicing into the correct grounds and power wires.
Thanks for the reply, ill double check everything tomorrow and let you know what i come up with.
1 - 3 of 3 Posts
