21 - 28 of 28 Posts
Addicted to Junk
'95 XLT: 5.8/MAF/E4OD/6" lift/4.56's/33x12.5x15
Pepe, You are missing something:shrug
Nah... it'll be fine. ;)
Hey guys I am adding a real pressure gauge. Can I put it i line to the remote filter?
That remote re-mount bracket I showed before had a hole on the top for a pressure sensor.
I capped it in my application but yours should too... I would think.
Those of you mounting remote tranny & oil filters, are you also keeping the original filter locations in place?
More specifically, the tranny oil filter inside the tranny oil pan which is a PITA to replace.
Are ya'll keeping that one or ditching it?
I guess now is the time for me to start researching alternative filter options since I've got my engine out and am prepping the bay for painting.
I too have the oil cooler set up on my 95 but didn't know there was a filter. How often should this be replaced? I have 180k miles on my Bronco. I'm replacing the radiator, electric fan conversion, overfill tank, upper and lower hoses, oil cooler hose, so I'm thinking I should do the filter while in there?
I change my oil and oil filter roughly every 3,000-5000 miles. Transmission filter should be changed every 30,000 miles or so with transmission fluid. More often never hurts.
21 - 28 of 28 Posts
