1 - 4 of 4 Posts
:banghead I recently put some water in my Ford Bronco because the temp was goin up. Now that is all taken care of. But since I put the water in there the oil guage keeps goin from normal to empty and back to normal. Its only in the morning tho. When I get off work it does not do it just when it warms up. Im not to mechanicaly inclined but I know that I did put it in the right spot. Also the engine light comes on when it hits empty. Does anyone know what is goin on? Please help.
Thanks in advance yall.:thumbup
Oh I did check my oil to and its in the normal section. So I know that Im goood on oil.
green ones make me horny
put a mechanical oil guage on it and see what you got. chances are it is the sending unit that is bad.
ken
Roller rockers are gay
:stupid, what ken said. the oil pressure gauge is nothing but an idiot light in a gauge layout. it doesn't tell you shit, nor does it tell you if it's empty :goodfinge : (j/k). it read normal as long as the sending unit gets 6.5psi of oil pressure (which is not enough really). or it goes to zero when there is well, zero oil pressure.
WOW ok my truck is finall fixed i think. it cost me $200 all together. the parts that needed to be replaced was the: oil sending unit-13.18, thermastat-7.12, therm gasket-1.20, by pass hose- 13.07, and clamps-4.00. I sure do wish i was mechanicaly inclined. but thaks for all of yalls help. i really appreciate it.
1 - 4 of 4 Posts
