Agree and you have given good information on dual catch cans in other threads, but this was an expedient bandaid to solve a problem, similar to the OP's, until the motor could be rebuilt.That was just on the Fresh air side of the PCV system there is also a Catch can that needs to go between the PCV valve and the Intake manifold Port to catch all the Oil and Crap being sucked up into the Intake manifold and being burned in the engine. You would have seen even more fluid in the other Catch can.
Did you purchase two of the same product, or one of each?These are the ones I bought on Amazon.
SPEEDWOW Oil Catch Can Air Breather Tank Baffled Filter With Hose Kit Universal Black
and
SPEEDWOW Oil Catch Can Tank Micron Bronze Baffled Filter With Hose Kit Universal Black
Good quality product. They were an easy install with all the connectors, hose and hardware. I just installed another set of these on a 1969 F100 390 FE EFI conversion project truck, still in the garage and up on jack stands.
Can you get a picture of the Bronco setup? I sure would like to see the installed setup so I can have something to go by when I get ready to do this to my '89.I bought one of each. Bought the one with the filter option on top in case I decided to change something down the line. I bought new PCV compatible hose to route them to the correct locations. I also relocated my PCV valve to the driver side valve cover, above cylinder #5, and moved the oil breather to passenger valve cover above cylinder #4.
I don't have pic of installation in our Bronco, but here is the installation in my '69 F100 project truck.
Thank you. I am going to order two of them and give it a try.Our Bronco is on an extended ski/fishing/work trip in the mountains so I can't get any pics of the installation. I installed them next to the stock air filter box on the driver side fender. Before I installed anything, I used an old garden hose and cut it up to figure out how to route the new PCV hoses. I used a lot of that old garden hose, but it was a cheap way to get the PCV hose routing correct.
Alternate location could be on passenger side fender wall near the battery. They don't have to be located next to each other because they work independently. But make sure that you can easily access them to remove the cups to empty them when needed.
