1 - 4 of 4 Posts
hey all ,, well popped the 302 in the broc,, would like to do the 460 swap but trying to get a sled puller together too
so i have a 351 cleveland sitting in the garage ready thought why not and do the 5 spd swap at the same time
prob is its a front sump pan none of the yards around here have a pan tube etc to put it in ,, its a 89 bronco
thought no prob order a new one but all the ones i find jegs summit etc have a double sump for mustangs and all say will not fit bronco
what did you guys running clevelands do?
or where did you order a pan?
thanks ahead for any help !!!
a 351M pan and pickup tube will do the trick. You should be able to find one
in a wrecking yard. If not, talk to your local machine shop. They should be able to source one for you.
yeap allready tried that,, prob is all of the yards here has crushed all the older stuff when the price of junk shot up
might have to try some yards farther away or look for a complete junk truck
thats the reason for trying to pick one up at jegs summit etc
thanks
or i might have to go ahead and do the straight axle swap ditch the ttb crossmember and try to use the front sump pan
1 - 4 of 4 Posts
