Yo C,
96 Bronco Oil Pressure Switch:
"The oil pressure switch controls the magnetic oil pressure gauge's pointer position. The oil pressure switch closes under normal engine operating conditions (oil pressure above 42 kPa [6 lb/sq in]). The oil pressure switch opens with the engine (6007) off and no oil pressure.
Check gauge operation as follows:
- With the key in RUN and the engine off, disconnect wiring connector at the switch. The gauge should indicate on the LOW graduation or below.
- Connect the wiring connector to the engine block ground. The gauge should indicate just slightly above mid-scale.
- If the oil pressure gauge tests within calibration, replace oil pressure switch.
- If the gauge still tests out of calibration, replace oil pressure gauge." by Ford
Is the idle high, or low or rolling?
Next up to bat:
Idle should be @ 675 RPM (per Ford factory spec).
Have you checked any Diagnostic Trouble Codes?
Try a Self Test for Diagnostic Trouble Codes by my pal, BroncoJoe19 @
Code Reader.....
With NO Diagnostic Trouble Codes, see Table 12;
Under Scope Engine, see if all of the 8 engine cylinders are getting spark. See
Part 2 -How to Troubleshoot a No Start (Ford 4.9L, 5.0L, 5.8L)
Quick Test is the test for Diagnostic trouble codes.
Fuel;
Check fuel pressure by obtaining a tester under local stores' rent a tool program with a refundable security.
Inspect fuel pressure regulator, pull the vacuum line; there shouldn't any gas or aroma thereof in it.
See my Vacuum leak test in post #11 includes jowens1126 HVAC Control Panel info @
Help with dtc codes and idle
If the leak exists in an accessory unit, such as the power brake, the unit will not function correctly. Or Air Conditioning when in MAX mode may switch to Defrost
For no codes, see Table 12;
Fuel;
