1 - 9 of 9 Posts
I just bought this machine a few days ago. It has a small oil leak. It sat for a few years. When I first started it, it had low oil pressure. I added oil and left the barn I found it in. When I was about 10 miles away the gauge went all the way low. I kept trucking. Made it home. Just started tinkering with it today. Started it again and the oil pressue was in the normal range. Took a trip around the farm and it went low again. I'm not a mechanic. Maybe should not have bought a toy but I'm sticking with it. What do ya think. The thermostat gauge is not working either. I do know that It is pumping water. Looks like the sensor is not there anymore. I think i found the oil sensor behind the carb and it looks like the wire is intact.
you probably have 8 valve cover bolts.
and I bet thats a 351M
and I bet the rods and main bearings are worn
and I bed thats where your loosing oil pressure
and I bet 20w50 might help it a little unless the previous owner put that in there already.
Put a real gauge in. I had a factory gauge on a 300-6 that read fine until the engine warmed up- then it would plummet. Real gauge showed I had good pressure all across.
It was the factory sender going bad once IT warmed up.
Probably don't even have to buy the gauge right off, i can practically guarantee you have a buddy with one hanging around that he'd let you put in your block for a 15 minute test.
MARBLE GARGLER!
I had the same problem in my '73 Ranchero with a 351c, I replaced the oil sending unit at the back of the block {same set-up on the 351m and 400 motors} all was fixed.... I'm not one to let well enough alone, I used a tail pipe cutter to open up the sender and it had a white corrosive lookin' powder on the mechanism that was keeping it from making contact internally. And NO it is NOT an on/off switch !
I'm with you. That was the story on my 94 when i bought it. Probably why i got it so cheap too...
another vote for mechanical gauge, and funky sensor
AND another vote for this engine has been running since Reagan was president and its plum wore out
added or changed oil
first thing if it has been sittin for a while, CHANGE the oil, or drop the pan and check strainer on the pump. i've seen um run with good pressure and all the sudden pressure drops, ...:smilie_slapSTRAINER
x2. The strainer can easily get clogged with crap that has entered the motor one way or the other. Last year I pulled 2 351M apart from different sources and both of them had clogged strainers from somebody using too much RTV. Also change out the sending unit for a good one, it's a possibility.
1 - 9 of 9 Posts
