Sorry, not very knowledgeable so excuse me if this isn't enough a great explanation.
But basically, here is what happends..
When my Bronco (88 351w) has been driving for a bit, 15-20 minutes or so. When I pull up to a stop sign it tries to die on me. The oil pressure gauge drops, then the red Engine light comes on and if I don't hit the gas, it will die.
This only happends after the truck has been running awhile. It can idle for ever perfectly and drives great at all speeds. It only happends when in gear and stopped (or just before while coasting to a stop).
If I throw it back into Park, it will jump right back up and Idle fine..
And again, for the first 15 or 20 minutes of driving around, this doesn't happen at all.. But like clockwork, (or for me a certain point in my 25 minute commute to and from work) it will start doing this.
Got over $3,000 into this darn thing the last couple years and its been a wonderful fishing and snow day driver. But I can't justify dumping the cost of having a mechanic replace the oil pump and from what I've read searching these forums, replacing it myself is out of my skill set.
So I'm just checking in for any other ideas before I throw a first one to come get it can have it sign up on craigslist.
Thanks.
Thanks.
