umm yes? Not quite sure what the question is. Yes, the oil gauge sending unit is on the drivers side of the block, about 1-2" foward of the oil filter. The oil pressure gauge is just an "idiot light" in our year models, though. As long as the sending unit has any pressure, the gauge will read "normal".. if you have 10lbs it reads the same as if you have 60lbs. :wacko. It's always a good idea to install an aftermarket mechanical oil pressure gauge. I installed one, used a t-fitting, and kept the factory gauge functional, too. :thumbup
