1 - 3 of 3 Posts
I haven't done a 460 swap in a Bko, but I just pulled one from a '77 Linc and sat in down in a 65 Galaxie! I can tell you that you will need a truck pan.
84excursion said:
84 bronc, 351. to 78 lincoln 460 with 4x4 c-6.
I need to switch the oil pump and pan to fit right?
And finally, do i just need to change the motor mounts, or is it the mounts, and the towers that connect to the cross member?
Thanks
im pretty sure you have to change the mounts. someone else will chime in here as i havent done this swap but i read of ppl who did. but i believe L&L makes a 460 swap motor mounts for what your doing. Hope you liek the price of gas, although youll prob be able to kick a mustangs @ss.
1 - 3 of 3 Posts
