After all your kind advice and recommendations, I removed the transfer case shift motor today. Easy peasy.
Anyway, while it was off I had this bright idea to TEST teh 4wd for the hell of it to make sure I didn't purchase a real problem child. Shifted into 4 high no problem, drove well, no noises! Bonus!! Then proceeded to try and test low gear at the case. After some effort with a pair of channel locks It went into 4wd low. Drove it a short way to make certain...it worked great!
Now, with the shift motor removed for disassembly and inspection, I tried to shift back into 2WD. Not a chance!! I could not even get the leverage to go back to 4 hi! I tried every tool I could think of...nothing was able to turn the shifter shaft quite far enough to go into 4wd hi. OR...am I missing something. Would moving the vehicle a little help it to shift back into high?
Any help would be worth a ton to me right now, lol. I'm sure there must be a simple way of doing this. I'm just too dense to think of it.
Truck in neutral when shifting in and out of 4WL?
You see what happens when you're a teenager in the late 60s/early 70s? I must've smoked all my memory cells away, lol.
MUCH thanks, sackman9975!!!
Too much malt, hops, and bong resin? ;) We all pull those Homer moments
