1 - 8 of 8 Posts
Condition must be near new. Not concerned about the belts or buckles just need the unsplit, gray female seatbelt “sheath”. Both sides
164778
Good luck, most are dried and cracked in my neck of the woods. Including mine, I zip tied the loop at the buckle to my plastic center box to keep it from hitting the floor.
Reactions: miesk5
Moderator and Scrounger Extraordinaire
Hit the junkyard. Supercab f150 have the same plastic sheaths.
I'm replacing my belts too. I'm looking at the LMC belts setup they have. Cost a little bit, but it looks like the have plastic covers (gray is backordered) for like 7 bucks for a pair, probably have to pay shipping too.
I might have these for you. Let me check. If so you can have them. I’m looking for the OEM “long” ones. Found a couple on EBay but pricey, Especially considering I will have to get them redone at seat belt planet again.
I have these and the metal piece if you want them. I’ll never use and you will help me clear out my free box!
165262
1996 Ford Bronco XL
Stupid question but can those sleeves be opened? I need to redo my seatbelts too and this is a rabbit hole I was about to go down
Reactions: miesk5
No. The new belts slide down there. I’m not the guy to ask about seat belts. I went with LMC on the front, had seat belt planet do all the rest. But I was an idiot and cut my perfect ones which I immensely regret. When I find my new (old) covers I’m going to have seat belt planet redo them to stock appearance.
1 - 8 of 8 Posts
