Alright i'm new here but i want to get some opinions. I bought a 78 bronc for $100 a few weeks ago. It runs and drives great, but the body is unrepairable. My plans are to make a very CHEAP truck that will equate to tons of fun on the trails and at the dunes. I was given a set of 17/40-15 ground hawgs for it. So far i chopped the fenders and lowered the coil buckets on the frame, gained 3". I need to get your guys opinions on how to clear these tires cheap. I don't mind putting in lots of work or time but i want this truck to be built cheap. I'v heard of a shackle flip but can't find much info, do you use the stock brackets? I do have a body lift for it but prefer not to install. Sorry for the long post.
I run 40in boggers with only a 4in suspension lift and 3in body. Lots of clearance. The 3in lift and plenty of fender trimming will work very good. I did trim about 3in off the fenders
those huge meats on the stock half ton stuff will break alot of parts.
sell the 40's, buy some 35's, with the money, and wheel the piss out of it.
When i lowerd the buckets i bent the bottom part over against the frame the i TIG welded them to the frame. I do have 35's that came on it but the 40's are way cooler! I'm not worried about breakin parts:doh: it has happened lots in the past and will happen again. Plus i've got a few Miscellaneous doner vehicles layin around where i can source parts.
www.easttn4x4.com
If you are on a budget then reuse the rear shackles and just flip them. I think you also have to move them 1" in when you do that.
