Been looking at a few on ebay (around $600) and then one on www.eatmyshift.com monster transmission (around $900). My son and I want to go wheelin. Bout time to get the Bronco up and running again.
Dont have the means or the motivation right now.man, $600 bucks sounds like a lot of coin for a t-case..why not score a used one and do a rebuild?
Im set on an electric 1356. This one lasted me through years of abuse.If you are going to buy a tcase new, go with a 205. A little bit higher gearing, but worth the reliability IMO.
Also if you are set on buying a 56 TRY TO FIND ONE WITHOUT THE SLIP YOKE! They differ all the time, I thought 250's for sure came without them, but it turns out some bronco's did and didn't some 250's did and didn't. I haven't been able to find a definitive yes or no as to when and what models. I think it differs on packages & Gvwr's.
My recommendation is 205, 203, or if you are set on a 1356, no slip yoke...
Why not go with manual then? Electric is the sole reason why it won't shift I'm sure. I'd do 1356, no slip, manual shift & manual locking hubs. Best combo IMO for reliability with that set up.Im set on an electric 1356. This one lasted me through years of abuse.
Already have it out since it started to sound like a train and the electric
motor hasnt been able to shift it for a while. I just want to replace it and go.
Ive no slip yoke and in my opinion its a low geared light weight tcase.
He'd need to build a brace for it though.If you are going to buy a tcase new, go with a 205. A little bit higher gearing, but worth the reliability IMO.
Is it really worth all that money to you though? I know how you feel about getting it done right, but you could buy a used case and rebuild kit and still be way under $600. You could then sell or dump your old one. I've never done one, but looking at guides online rebuilding t-cases doesn't look that difficult. One question though, if you don't have anywhere to work on your truck, how/where are you going to swap in the new t-case?Im just trying to avoid getting one in the same or nearly the same condition as mine.
pulling it with you and a friend is pretty easy. find a place to drain what fluid you can in a container, and take her on inside:Problem is there is only so much I can do in my condos parking lot. According to the association we aren’t suppose to work on ANYTHING
at all there.
Friend of mine was a mechanic and we would use his shop in the past. Thats
how I got the truck to where it is now. Unfortunately he changed professions.
I've got a manual 1356 to replace my auto and was meaning to tear it apart and do a rebuild. What kit(s) did you use?pulling it with you and a friend is pretty easy. find a place to drain what fluid you can in a container, and take her on inside:
Spare bedroom years ago when I did mine:
and Here ya go, this ones inside taking a shower:
great learning experience, and if you get a reasonable miles manual you shouldn't need much. Less than $600 for sure.
Im looking at other options now. I do work on the truck in the parking lotIs it really worth all that money to you though? I know how you feel about getting it done right, but you could buy a used case and rebuild kit and still be way under $600. You could then sell or dump your old one. I've never done one, but looking at guides online rebuilding t-cases doesn't look that difficult. One question though, if you don't have anywhere to work on your truck, how/where are you going to swap in the new t-case?
