just recently my bronco has developed a very annoying electrical issue. when i go to turn the engine over something "disables" my electrical system; the entire electrical fails no blown fuses or anything. i checked the battery and it has proper voltage and amperage. if i disconnect the battery and reconnect it will sometimes start right up. my 94 f-150 has done this twice also. anyone have a clue for this sporatic problem?
press ALT+F4
loose ground?
loose/corroded battery cable?
broken battery terminal (inside battery)?
Also check the terminal at the starter relay and see if it's clean and tight.
the starter relay and the battery connections are clean and i have also cleaned every gound connection when i first got it. everything goes out the lights the horn then all of a sudden it gets full electrical power.
trying to go fast!!
loose ground?
:thumbup
