1 - 10 of 10 Posts
Offical FSB Map Maker
Ok it's not a bronco but I think some of you master mechanics can help me out here. I have a neighbor that has a early 90's Ford Explorer Sport, 4.0L, 65,000 orginal miles. Yes that's correct she doesn't drive like a nut and is an older lady. It's probably never been over 65 MPH. Anyway, it's over heating. I don't see any leakage anywhere around the block. No water/oil mix. I took it down the road and it gradually got hot. Came back to the house and the top hose to the radiator and all heater hoses were very hot. I checked the lower hose and it wasn't even warm. So I am thinking that maybe the thermostat isn't opening or the water pump is shot.
So anyone got any ideas as to which one it is or could it be something else?
Also something to check.... If I recall some of the newer cars have an electronically controlled thermostat.... There is a wire that goes to them and if it becomes disconnected the thermostat will not work.... Could be something as simple as that but thermostat nonetheless....
I don't know if the exploders are that technologically advanced though....
I just left an explorer (For my bronco :) ) If it's a '91-94 (First gen, the boxy type) it's most likely the thermostat. Had the same exact problem on my '92. It's only a $4 part, just make sure to get the right gasket as they list two but only one fits right. If not just use some RTV gasket maker. It's only 3 bolts that hold it on. Two are a major PITA to get out but after tearing up your knuckles you'll be able to get it out :) They claim you need to drain coolant first but I just jacked up the front end and dealt with the small spill. Good luck!
EDIT: I should add that there is no electrical connection on the first gen X's I don't know about any later models. It simply sits there and does it's job.
1 - 10 of 10 Posts
