yo!
Had almost same situation in my 96 a few yrs ago;
I need to look for my notes on what fuse blew due to a harness short under steering column that affected the OD Cancel Light (it blinked randomly, no Trouble Codes or tranny malfunctions though); Doesn't matter what fuse it was since it is diff in your year anyhow...
Here is a TSB that deals with it; for a 92 though.. and may apply... even tho year range is off... and your OD sw is in dash and 96's are on end of tranny stalk....but... itsa pure guess on my part..and it's an ez no $ check anyhowz
1992 Ford Truck F 150 4WD Pickup V8-351 5.8L
Vehicle Level Transmission and Drivetrain Technical Service Bulletins Customer Interest Electrical Systems - Multiple Malfunctions
Article No. 92-22-5 10/21/92
LIGHT TRUCK: 1992 BRONCO, F SUPER DUTY, F-150-350 SERIES
ISSUE:
The transmission control switch wiring may be misrouted causing a short in the steering column and a blown # 17 fuse. The following symptoms may be associated with this concern.
Early shifts
Loss of power
Poor acceleration
3-4 shift cycling
Transmission control light cycling ON/OFF or inoperative
Transmission control switch inoperative
Rear Anti-Lock Brake System (RABS) electronics (dash lights on, etc.) inoperative
Loss of instrumentation (tach, fuel gauge, etc.)
Unable to read Self-Test codes (solid tone only)
ACTION:
Inspect the transmission control switch wiring for damage and repair or replace as necessary. Refer to the following procedure for service details.
1. Remove the steering column cover. Refer to the 1992 Bronco/F-Series Service Manual, Section 11-04B, for the removal procedure.
2. Examine the transmission control switch wiring for damage, Figure 1. (I don't have this Figure)
3. Repair or replace the wiring as necessary.
4. Install the steering column cover. Refer to the 1992 Bronco/F-Series Service Manual, Section 11-04B, for the installation procedure.
CAUTION:
DURING REASSEMBLY, ROUTE WIRING AWAY FROM ATTACHING SCREW SO AS NOT TO PINCH OR DAMAGE WIRE.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS:
Eligible Under Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
922205A Repair Wiring 0.6 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
15A808 X1
OASIS CODES:
201200, 203200, 204000, 206000, 301000, 501000, 503300, 504000, 614000, 614600
Can you pls explain this? "...codes are none to nearly all of them. Nothing consistent..."
What Codes, if any came up in both KOEO & KOER (with eng at normal op temp)?
ISSUE:
Early shifts
Loss of power
Poor acceleration
3-4 shift cycling
ACTION:
CAUTION:
WARRANTY STATUS:
DEALER CODING
15A808 X1
OASIS CODES:
