Ok...here's the deal, I'd like to go with as high of an axle ratio as I can...but 4.56's would push rpm's on the highway a little higher than I'd like...and I'd like to go higher than that...like 4.88 or 5.13. I don't drive much on the highway, but I would like to take more trips...and, I definatly need the as much gear as I can get offroad.
That leaves an overdirve trans, unless I kept near stock gears, and went with a 4spd manual with a granny low. Trouble is...after all the researching I've done, all the options suck.
AOD-never made in a big block bell housing, and debatably flawed internals. Expensive adaptor plates make it possible, but not anytime soon.
E4OD-from what I understand, they did make it in the right bellhousing, but you'd need some sort of expensive electronic module for it. On one hand, I've heard they're essentially a c6 with an overdrive gear/on the other, I've heard that they suck, and are prone to problems. But, I think iirc that the 205 would still bolt up.
Then, there's the option of an automatic overdive unit...which seems great...drops right in place of the tail housing of the transmission from what I understand. Kinda makes your 3 speed a 6 speed...but they're probably the most expensive option out there. Has anyone gone this route?
And, is there anything I'm missing, or any other options? I wouldn't mind going to a stick shift...but it's kind of sucks to have to deal with all the clutch pedal crap. Any suggestions or corrections are greatly welcome, and appreciated. Thanks, Jared.
