1 - 8 of 8 Posts
I recently purchased a 1994 Bronco that had a blown engine. After replacing the engine, and chasing down all the electrical problems I have a problem I can't fix. The overhead console comes on for about 5 seconds when the key is first turned on, and then it goes out. The display shows "188 e var/cal 00
Any help would be appreciated
Designated Tranny Killer
hey, bud, there is no such thing as a '97 bronco
I recently purchased a 1997 Bronco that had a blown engine. After replacing the engine, and chasing down all the electrical problems I have a problem I can't fix. The overhead console comes on for about 5 seconds when the key is first turned on, and then it goes out. The display shows "188 e var/cal 00
Sounds like your compass isn't calibrated.
Hoping it is just a typo. His profile says 94...haha.
Take the overhead console down and make sure all your connections are correct.
There's an old thread here about someone with that problem - he ended up pulling the module out & replacing a transistor or something on the PC board. Do some searching. :deal
If you don't want to fix yours, I have a damaged console with (I think) a good module that I could be separated from... ;)
do you want to get rid of module
1 - 8 of 8 Posts
