Hi all,
My blower motor started to cut in and out, so I dove in trying to figure out what was going on.
For starters, the blower motor is less than a year old.
I thought maybe it was a loose connection, so I started rattling the connections until it turned back on.
It turned back on when I fiddled with the connector that ties the blower motor into the main harness.
I pulled it apart, and it was burned and melted:
164383
I cut the plugs out and replaced them with two watertight spade connectors:
164384
However, I have no idea why this happened. The blower motor works fine and pushes plenty of air.
What would cause it to overheat like that? Ideas?
If it’s just melted there, no signs of heat damage anywhere else, I would assume just a crappy connection in that connector causing arcing
Reactions: packagerjr
That was my assumption. Bad connector, corrosion, etc. etc.
The wires outside of the connector were fine.
Just wanting to be sure before I turn my eyes away from it for a while.
It’s a bronco.... NEVER turn your eyes away from it.... it’ll sneak up a steel the money right out of your wallet!
I only meant the plug!
The rest... never.
