A few months ago my bronco started overheating during normal driving. I replaced the thermostat and temperature sender and the problem was solved, it was running great.
About a week later it started again, and here's what I've noticed:
It doesn't seem to be leaking fluid from the thermostat housing.
After multiple flushes my coolant still looks like rusty water+antifreeze
If I crawl underneath the truck theres a couple drops of coolant hanging from behind the harmonic balancer area.
I read in a few threads this could be the water pump weep hole, but I want to verify before I start working on changing the water pump.
I have reason to believe the previous owner used that radiator stop leak gunk, and curious if I should go ahead and replace the radiator and heater core even though I can find any leaks since it may be gummed up with crap.
I've never replaced a water pump, and I have to rent a booth at the auto hobby shop on base, but that only gives me about 8 hours to complete it, or I have to pay to store it there for a week until the next weekend rolls around and I have time to get to work again.
Any tips/tricks or other ideas would be appreciated, I don't SUSPECT the thermostat has gone bad again in just a weeks time, unless the crap in the coolant clogged it, and there still is the coolant behind the harmonic balancer so there is a small leak somewhere.
Thanks!
-Alex
Thanks!
-Alex
