1 - 2 of 2 Posts
Read Only
I have the Procomp 6 inch leafs in rear. I believe the bottom straight leaf is the overload leaf correct?
Can I remove that while still on the vehicle using a couple c-clamps with no weight on the leaf packs?
I have too much rake on the vehicle, kinda annoying. Will I need an alignment after? Been on for few
years now. Hasn't settled much if any since installed.
1987 Ford Bronco, 460, zf5, JBG HD rear springs, JBG 4” coil, 10.25 rear posi, Dana 44 posi
I’m not sure if I would take the overload spring off but you can take one of the leafs out above that. I do know you defiantly won’t need to get an alignment that’s only if you touch the front end. And yes you can use c-clamps to do it.
1 - 2 of 2 Posts
