1 - 19 of 19 Posts
i need the two springs the cast spacers and the 4 frame bump stops its fro a 4wd f-150 but i think the 250 stuff will work also.
I have the springs but unfortunately nothing else..... let me know if you end up having to piece it together..
what yr. rig you working on? I am getting ready to part out a 87/88 f250 w/ 3" wide rear springs and I also have that set up for 73-79 f series... in NJ
i just sold my 96 f-150 that had the overload springs on it. i am buying a different f-150 of the same year that dosen't have them so i just want to install them. i haul alot of mulch and gravel, so they work well for me.
take a pic of the rear suspension and i'll see if you have what i need (the 87/88)
F-250's have 2" spacers. F-350's have 3" spacers, at least the one I had did.
are you talking about the cast block that sits on the spring perch under the leaf springs?
if not, sorry for the confusion. i need the spacer on top of the leaf pack
Thanks 351w500
I have no idea of what cast piece's go on top of the leaf's??? There is just the wedges and the blocks that Dustball put up and the spring plate on top. Are the over loads aftermarket??
Thanks 351w500
WOW Sticker shock. I dont think ive seen any OEM overloads. I know with a price like that I would never buy them new.
You might want to try and hit the JY
Qty. Part # Description Unit Price Amount
45-1212 BRACKET-AUXILIARY SPRING 4 REQ 39.95 $159.80
In Stock
45-1215 SPACER-AUX LEAF SPRING 2 REQ 139.95 $279.90
BackOrder
45-2906 AUXILLIARY SPRING 2 REQ 109.95 $219.90
In Stock
Parts Total: $659.60
Discussion Starter #17
In Stock
BackOrder
In Stock
exactly why i'm looking here and local jy's
I guess I should not have scrapped the set I took off a truck a few months back:banghead:doh0715::banghead:doh0715:
1 - 19 of 19 Posts
