1987-1989 Speed Density Truck
3-wire HEGO (Single)
HEGO SIG at EEC Pin #29
HEGO GND at Sensor body
1990-1995 Speed Density Truck
4-wire HEGO (Single)
HEGO GND at EEC Pin #49
1994-1995 5.0L Mass Air Truck
HEGO SIG at EEC Pin #44
HEGO GND at EEC Pin #46 (SIG RTN)
1995 5.8L Mass Air Truck
4-wire HEGO (Stereo)
L-HEGO SIG at EEC Pin #43
R-HEGO SIG at EEC Pin #44
1987 5.0L Speed Density Mustang
3-wire HEGO (Stereo)
L HEGO SIG at EEC Pin #43
R HEGO SIG at EEC Pin #29
1988-1993 5.0L Mass Air Mustang
1994-1995 5.0L Mass Air Mustang
MAF Upgrade Notes:
- You can use a 3-wire HEGO in a 4-wire Harness Connector.
- You cannot use a 4-wire HEGO in a 3-wire Harness Connector.
- When using the A9L/A9P Mustang PCM, use stereo 3-wire HEGOs.
- When using the WAY1/VEX1/AKCO PCM, use a single 4-wire HEGO.
- When using the BIO0 PCM, use stereo 4-wire HEGOs.
HEGO Sensor Connector
HEGO 4-wire Sensor Connector
HEGO 3-wire Harness Connector
HEGO 4-wire Harness Connector
Speed Density 3-Wire Single HEGO (Before 1990)
12v PWR -
P/O from Relay/Fuse Panel
12v GND -
BK to G-101
HEGO SIG -
DG/P from EEC Pin #29
SIG RTN - GND at Sensor body
Speed Density 4-Wire Single HEGO (1990+)
12v PWR -
12v GND -
BK to G-101
HEGO SIG -
GY/LB from EEC Pin #29
SIG RTN -
O to EEC Pin #49
MAF Stereo 3-Wire HEGO (A9L/A9P)
12v PWR -
GY/Y from Relay/Fuse Panel
R 12v GND -
BK/W to Body GND
R HEGO SIG -
12v PWR -
L 12v GND -
BK/W to Body GND
L HEGO SIG -
R/BK from EEC Pin #43
MAF Single 4-Wire HEGO (WAY1/VEX1/AKCO)
12v PWR -
12v GND -
BK to G-101
HEGO SIG -
GY/LB from EEC Pin #44
SIG RTN -
GY/R to EEC Pin #46
MAF Stereo 4-Wire HEGO (BIO0)
12v PWR -
R 12v GND -
BK to G-101
R HEGO SIG -
SIG RTN -
GY/R to EEC Pin #46
12v PWR -
L 12v GND -
BK to G-100
L HEGO SIG -
SIG RTN -
GY/R to EEC Pin #46
