I just called to order panel adhesive to install repair panels.
I talked to my body guy I have used for 16+ years and is always up on the newest technology and tried most of these products himself.
I asked him about the 3M panel adhesive. His response was how long are you going to keep the vehicle?
He used the panel adhesive on his truck 10 years ago. He did everything he was supposed to do and then some steps that most of us would skip.
He said by 8 years the panels still looked perfect except the seam where the repair panel was glued on has bubbled up and rust is running out. By 10 years it is so bad there is nothing to repair or attach a new panel to.
So now he is either going to have to do extensive welding or give up.
He says the epoxy of course has moisture in it and that was trapped when the layers of filler and paint were put on it. It rots from the inside out and there is nothing you can do to stop it.
This is also on a truck that only comes out on nice days, so there is no other way it could have rusted.
We he conferred with the 3M rep about it their response was simply that it is not normal to keep a vehicle that long and not what the product was designed for.
Has anyone else here had panels glued on that long?
