I've been noticing from time to time as the passenger front tire hits a bump that something is a little loose. I've replaced all four ball joints about a year ago, roughly 8,000 miles. I jacked up the front passenger side to run the old ball joint test and in moving the tire holding in the 12 o'clock/ 6 o'clock position there is a decent amount of play. I checked the ball joints as I moved the whole assembly and they seem tight and didn't move at all, everything from the brake rotor- outward did however. I also noticed the outer hub cover held on by the alan head screws was a little loose and could be wiggled slightly by hand. I dont think it's ball joints because of this but am throwing it out to you guys for more analysis. thanks
