Non AC Heater box
I have to eliminate factory heater so I can install an aftermarket AC / Heat system.
This means I have to figure out what to do with the passenger side fresh air in the kick panel.
My search foo is not strong today. Somewhere I recall someone adding a fresh air vent control to the passenger side similar to driver's side. My brain is telling me they took a vent from the driver's kick panel and flipped it so they could mount it on the passenger side.
Does anyone recall this or have other ideas for the passenger kick panel? I would like to keep something functional rather than just blocking it off.
trucks that came heat only have a vent on the passenger side. If you can find one you are in buiness
They like to leak so often there is a cap in place
Mine has a vent but it is built on the heater box. It is not like the one on the driver's side.When I get rid of the factory heater that will be gone.
Not worth making the factory air functional? I retrofitted mine and it works great, both heat and AC.
