1 - 18 of 18 Posts
Addicted to Junk
Up for sale are two small bolt (10mm) saginaw bracket kits for serpentine smallblock fords. They include the AC compressor mounting surface.
Each "kit" contains the following
  • cast bracket for mounting the Saginaw
  • saginaw pump, used, with pulley
  • all mounting hardware
  • reservoir cap
The old lines are still attached, and as you can see, I had to cut one. Pumps spin freely and could easily be rebuilt, if need be.
$125 EACH shipped to the Lower 48. Other locations may incur additional charges.
I prefer PayPal, but accept checks as well. I wont ship until I have cashed the check or recieve PayPal payment.
Addicted to Junk
Would they fit a 400?
No, and I'm sure those are nearly impossible to find. Most vans had 351 Windsor's. One from a 460 might fit. I'll have to check. The good news is the same bracket that 460s use, I've found on a Windsor as well. Are you serpentine or V-belt?
vbelt
Addicted to Junk
K, I'll see what I can do. I did pull a York ac compressor and bracket from an M-Block last time.
Addicted to Junk
TTT
Reactions: miesk5
Addicted to Junk
Do you have a full "kit" for my 96? Where are you in Kansas? I'm in the kc metro on the Missouri side right now.
I work in Topeka, about an hour west of KC. Live just a bit north of there.
What I have is the bracket, pump and cap, pulley, and bolts for smallblock ford v8s. The hoses are generally junk, though I have one with the old lines still attached. Nothing has been cleaned off either.
All you would need is a new line for the high pressure side, which you should get for a 96 econoline, with a 351w or 302. The low pressure return to the pump can just be a rubber hose.
Can you set it aside. I've got to go out to Lawrence to Midwest mustang sometime soonish to pick up a set of heads. Pm me your number and we can coordinate when to meet up.
Addicted to Junk
Discussion Starter · #9 ·
Sure thing! I'd like to check out the two Broncos they have at MWM as well.
Normally I have Thursdays off, but not this week. I work till one on Saturdays. I'll send a PM your way with my number.
Are you familiar with the pick n pulls in KC? Theres six of them, 4 in KCMO. 3 are just north of the stadiums off I think the eastern loop of 435. One in liberty too. There are a few econolines up there now with the right setups too.
Addicted to Junk
Discussion Starter · #10 ·
So consider one of these setups sold. One remaining
Reactions: miesk5
do you still have this pump?
Reactions: miesk5
Addicted to Junk
Discussion Starter · #12 ·
Reactions: miesk5
I have a fairly new one from O'Reilly's that I've never been happy with , this will be an upgrade ?
If so p.m. So we can figure this out
Reactions: miesk5
Addicted to Junk
Discussion Starter · #14 ·
Both sold. Closing thread for now.
Addicted to Junk
Discussion Starter · #15 · (Edited)
Got three more 5.0L/5.8L saginaw conversions in stock. These are the small AC bolt variety fitting i think 90+ engines. If your AC compressor bolts use a 10mm socket, this is for you!
Pump, Pulley, Bracket, Cap, and 7 bolts included. $125 shipped to the continental US. Other locales are extra.
Two have the old lines, though id buy new. Just compare them to what you need; a line for your model year and engine of econoline. All ford econoline v8s of this era actually used the same high pressure hose. One bracket is missing the locating pin tab. This is usually done so you can change the water pump without removing this assembly. It in no way affects the integrity of the bracket.
Pic showing the one bracket with the locating pin tab and one without.
Reactions: zainyD and miesk5
Addicted to Junk
Discussion Starter · #16 ·
Bump. Still got 3 5.0/5.8 serpentine setups
Also a bracket for v-belt 300s. And a setup for a v-belt 302/351.
Reactions: miesk5
Addicted to Junk
Discussion Starter · #17 ·
One Saginaw sold, 2 left.
Addicted to Junk
Discussion Starter · #18 ·
One more saginaw sold, and the last one has a potential buyer. So for now consider me out of stock... Ill close the thread when i confirm the last sale. Ill re open it when i get more Saginaw setups.
Reactions: miesk5
1 - 18 of 18 Posts
