I read some of the balljoint writeups, and I understand the process alright, but doesn anyone have a pic of exactly where you put the seperator fork to hit with the hammer? Thanks, I would appreciate it!
Thanks I will try that.Remove the castle nuts from the upper and lower ball joint as well as the tie-rod endthen, using a small sledge hammer beat the knuckle until it falls off. If you are planning on replacing the upper balljoint beat the stud of the upper balljoint. That's the way I do it anyway. To remove the balljoint buy/rent/borrow a ball joint press and press out the lower ball joint first and then the upper. Reinstall them in reverse order.
I was originaly going to do them myself, but I am going to have all of the spindle studs pressed out and new ones installed. So I figured they coudl press they balljoints in while the knuckles were at the machine shop.Unless your going to a shop to press the ball joints on i would skip the fork and just rent a ball joint press
i use the hammer method but i usually hit the side where the ball joint stud goes through the beam, typically it's only one or two whacks.Remove the castle nuts from the upper and lower ball joint as well as the tie-rod endthen, using a small sledge hammer beat the knuckle until it falls off. If you are planning on replacing the upper balljoint beat the stud of the upper balljoint. That's the way I do it anyway. To remove the balljoint buy/rent/borrow a ball joint press and press out the lower ball joint first and then the upper. Reinstall them in reverse order.
i bent mine:cryGo to harbor freight and get this
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38335
