1 - 9 of 9 Posts
I was wondering if someone could give me a location and dimensions I could use to check the height of the suspension lift on my truck?
On a second note, I have a 460 under the hood, and that drops the front down a bit over a small block, are there any springs (depending on what I determine to be my lift height) to bring the front back up a bit?
The truck:
I will measure to the bumb stops. Can't measure to the lip of the wheel well for two reasons: 1 body lift, 2: fenders are cut.
suposing that my suspension lift is maxed (8" on TTB correct?) is there any way to get another inch or two out of the front to level the truck out, or just have to lower the back to even it out?
A broke kid with a bronco
Spring spacers like a leveling kit possibly. I'm not sure what it will do to the center u-joint though and alignment jobs. It *may* work.
1 - 9 of 9 Posts
