I need a plastic square thingy that clips onto our tailgates. It rubs against the rubber stop on the spare tire carrier. I don't have a clue if it has a name haha. I've been trying to find one online with no success. Any ideas?
Thanks
yo D!
Where do you see it in this diagram?
Swing-Away, Type 3 (90-96) Parts Break-Out Diagram (in Swing-Away Tire Carrier (Type 3) TSB 90-07-13 for 90 Bronco)
Source: by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/253955
Swingaway Tire Carrier (Type 3)
The label in the diagram is wrong. This type was used from '90-96.
Service replacement EB tire cover: F4TZ-9845026-AAC
This style of spare mount requires a locking lug key (part of #6) as shown here
http://www.supermotors.net/getfile/544845/thumbnail/luglock.jpg
TSB 90-07-13
Publication Date: March 28, 1990
LIGHT TRUCK: 1990 BRONCO
ISSUE: High latching and operating efforts of the swing-away spare tire carrier may be caused by a lack of lubrication on the latch and striker assemblies.
ACTION: Lubricate the swing-away spare tire carrier latch and striker assemblies. Refer to the following procedure for service details.
SERVICE PROCEDURE
1. Make sure the spare tire carrier is latched. Both the primary and secondary latches must be engaged.
2. Spray multi-purpose grease (D7AZ-19584-AA) onto the latch mechanism located on the vertical bar of the swing-away carrier.
3. Make sure the tailgate striker is in the full up position and square. Do not allow striker misalignment.
4. Close the carrier.
* Both the primary and secondary positions must be latched.
* If the carrier does not latch, re-adjust the tailgate striker as required.
5. Lubricate the roll pin on the striker and the portion of the striker which engages the rubber sleeve on the carrier.
PART NUMBER PART NAME
D7AZ-19584-AA Multi-Purpose Grease
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under Basic Warranty Coverage
OPERATION DESCRIPTION TIME
900713A Lubricate Tire Carrier 0.4 Hr..."
I think it is the number 8 (the numbers are hard to read) - the spare wheel scuff pad. Well atleast I know what to call it now... thanks man. Any ideas where to get one? I'm going to take a wild guess and say ford won't have any, but if they do I know what to call it now!
ok, You can go to the direct link at Steve's page @ http://www.supermotors.net/registry/media/253955
then Right Click on the diagram to enlarge it
that is merely a piece of nylon or polyester reinforced tape; glue it back on or use a piece of rubber/tire patch.
