1 - 8 of 8 Posts
Alright boys and girls, i just got a white 96 bronco, and there are some things i would like to do with it.
#1 How do i take off manual window cranks?
#2 what paint should i use to repaint the inner door panel and entire dash
#3 where can i find/buy some of those interior hardtop trim panels
#4 the old guy i bought it from used it as a hunting truck so he basically
gutted the entire thing out. he even replaced the interior's back panels with this crappy fiberboard....WHO DOES THAT, HONESLTY. I need to do something about them and i dont feel like replacing the old boards with new boards. where can i find some????????????
Make sure to introduce yourself in the introduction section. Welcome to FSB.
#1 Lift the flap on the crank with a small screwdriver and take the phillips screw out.
#2 NAFC
#3 broncograveyard.com, lmctruck.com, junkyard, ebay
#4 Same as above
Welcome to FSB and don't take the onslaught that you're about to get personnel. When I first started comming to FSB I spent about a month and a half just searching past posts. There's soo much information out there you could publish 2 or 3 books.
Teddy Bear
on your manual window cranks there is a tool you slide under that bad boy and it pops the retaining clip off, the paint i suggest either vht or krylon fusion for plastics, for those panels, 1 check you local junk yard, 2 ebay, 3 search around there are ppl that are parting trucks and you can pick them up there, but other than that id say welcome and enjoy your bronc
Practicing Infidel
Get on down to the local junkyard, like was suggested by Da_Bronco_boi
A 96 is only 10 years old and everything doors forward is related to the single most popular vehicle in the world, the F-150.
VHT is the big vinyl paint manufacturer.
Sixlitre
1 - 8 of 8 Posts
