1 - 8 of 8 Posts
Practicing Infidel
The Legend said:
Does anyone have a part # or any info for a set of nice and tight fitting plug wires for a 351W? The stock replacements are WAY too long and look like crap. I also need 90 degree plug boots and distributer boots. I've got the TFI distributor.
Most sets will have the 90 degree boots at the cap
Don't you want the 135 degree boots at the plug, like stock ? Smallblock Fords do much better with 135 degree boots at the plug.
Taylors are available for your specific application in PDF form here;
http://www.taylorvertex.com/PDFS/Page41-52.pdf
After you've found which type you want and which colour, go to Summit and plug that part number into their search area and away you go.
Are you sure the Ford Racing wires, available quite reasonably at the stealership, don't fit well ? Mine fit as well as my Taylors or better.
The deal I was offered at the stealership last time, I just couldn't pass up, as it worked out cheaper than the Taylor SpiroPros.
Sixlitre
i just got a universial ford racing set and cut them to length..they are sweet!!
I've done the custom cut to length ones but for some reason I always have a problem. I have the 135's on it now and that angle doesn't seam to want to work with my headers. I will probably end up with another do it yourself kit. I have heard of some 12mm wires out now. I may have a look at them. I didn't know Ford had some descent plug wires available. What year would I tell them?
summit has them or im sure you can check them out at fordracing .com
Practicing Infidel
My headers are pretty happy with 135s from Taylor
Even a small Ford stealership can order the Ford Racing wires for you, if they don't already have em' in stock.
Here's the Ford ones, in black, on my Lincoln (where I want them looking stock);
Thick enough for you ?
Sixlitre
1 - 8 of 8 Posts
