This noise pop clunk(one time) when i turn backing up or sharp turns going forward in the front end has been worring me for a while now so i decissed to take it up on the lift at work. I found that my pivot bracket was only hand tight:shocked so I got all new hardware with lock tight and washers (Grade 8) checked all bushing down under there everything was tight, (Pivot bushings are a little beat.)
SO I figure everything should be good and fine now and I won't get this pop clunk sound when i turn backing up or sharp turns going forward. so I go to back it out of the shop and what happens!? It DOES IT AGAIN! what ever it is I figured having the brackets loose caused it so I bring it onto the alingment lift with the turn plates on it and have someone get inside and turn the wheel. it seems as if the whole drivers side wheel shifts back when turned and the Axle shifts up making the pop clunk sound where the drive shaft and the pinion meet. I looked at it for a good long whie and couldn't figure out what would make it shift like that ball joints are tight Rad arms are good. so what could it be? sometinhg in the diff!? the U joint? axle pivot bushing? I'm not sure.
I'm not sure if what i stated above can be understood so I'm going to rewrite it.
When the wheel is turned backing up/going forward to almost full lock it seems as if the steering knuckle shift back cuasing the axle to shift up making the drive shaft were it meets the pinion pop clunk.
I can take video if needed.
Info:
1992 Bronco Xlt 302 E40D 6in lift drop rad arms
Info:
