41 - 60 of 1778 Posts
this is my bad boy @ the shop after a bad night of offroading, high centered her on a few logs hehe "few" and knocked my tranny real good, need to get a new c6 tranny before i can take her out again :cry
I guess I can squeeze some pic's of the little guy in here. :thumbup
This is one of the few pic's I have of it before it was done. I had the frames stacked and the 2.5 ton toploader Rockwell axles mounted under it. But it was to steep of a angle for the drivelines, so I had to pull the married 4 speed transmission and t-case out and put a 2 wheel drive tranny and divorced t-case in to step it down. If ever I get the 460 Merlin block done and ready to install, I think I am going to put a automatic in it. The "granny low" four speed is just to slow on the shifts.
:shrug
This is the end results. Dark Blue base color with mini flake and Mirage on the center strip ( changes colors as you go by ) body paint. Frames are Grabber Green, and suspension is Grabber Yellow. 20" of total lift, on top of the axles and tires (45" x12" on 20" wheels)
:beer
Here it is pulling a stuck friend (1966 4x4 international P/U) out of the swamp. :histerica
I gave him a set of 33"x12.50 tires after the second time of pulling him out of the same hole. Those skinny 31s were not getting the job done.
:drinkbud
I had to play a little while I was there. The dent in the top was from a earlier trip into the snowy hills and I laid it on its side! (Too much speed + snow that had thawed then re-froze into ice + down hill corner = OH $H!T)
:shrug :duh :banghead :wacko :toothless
One of these days I want to get my 55" x 24" implement tires on it also.
The 45" military tires are starting to get a little thin on tread.
(Now if my brother would just get that little ranger 4x4 out of the way I would go home)
:slap :histerica
stangmata50l said:
That thing is rediculous :thumbup
could be....BUT THE CHICKS DIGGIT...:thumbup :chili: :chili: :chili: :hump :hump :hump :bday :clap ....LOL
scrounger extrordinaire
2.5, i said it before, i'll say it again, nice truck.
nate are you sure they were humvee tires? are they 40x20? i didnt think humvees ran those. i know the bigger trucks run them. thats what Jopes is running and as soon as i can afford some 20s i will be sporting them too. with spinners i hope :wacko
Thanks guys. It was fun to build it, and even more fun to play with it. But one thing I haven't figured out is why it doesn't get as good of MPG's as it did when it was stock ( ya think its got a leak somewhere? )
:shrug :histerica
old79bronco said:
I like your Bronco and I REALLY like your back yard test track.....
:clap :thumbup :histerica
Hey muxpux is that the bronco I saw sitting with the for sale sign at the castle rock exit? I like it either way! Where were you wheelin at when you took those pic's, it looks like familiar scenery. I live just up !-5 a few miles from you.
:thumbup :beer
Professional Crastinator
:thumbup :beer
it could be, i just bought it last st. patty's day. 1500. the guy i bought it from lived way out the end of Abernathy Creek Rd.
i was wheelin at Dibblee Point beach in Rainier WA, just west of the Lewis and Clark bridge that connects Longview with Ranier. the one where you see the "city" in the background is the port of longview. its also the same scenery seen in the movie "men of honor" as that is where they did some on location filming. (the parts where he was in divers training)
anyways, i know where onalaska is (kinda) never been there before though.
heres the latest.
nothing you can see really. got a tach added. rock lights wired. i think i am going to gut the heater - a/c stuff to clean up the engine compartment. put in an aftermarket heater or a rear van or suburban heater. looks like its becoming more of a trail rig thats street legal
'79 Ranger XLT Free Wheelin' Edition
I just got some pictures of the truck, my camera broke and I had to borrow my brother-in-law's camera. I posted in the engine thread already.
A little bit of info:
I bought it in 2000 for $1000.
1969 460 .060” over
C9VE 75.8cc heads 2.08 intake 1.65 exhaust
Crank ground, spooned and balanced
TRW L2443F-60 forged pistons cut & balanced to 11:1
Stock rods, shot-peened, polished, balanced, ARP bolts
Rotating assembly balanced, deck zeroed
Hi-Vol. rear sump oil pump
7 qt. oil pan
Comp Cams Xtreme 4X4 FF X4 270H-11 270/278 226/234 554/574
Crane Energizer 1.7 roller rockers
Hardened valve seats
3-Angle valve grind
Port, polish, gasket matched
Edelbrock Performer RPM Intake Manifold 7166
Edelbrock 1411 750 CFM, electric choke
4 core radiator
L&L mounts, headers and brackets
C6 Cottman rebuild
HD RV torque converter, Transpak RV setup
NP205 transfer case, new bearings & seals
Dana 60 front axle, disc brakes, Powr-Lok L/S, 5.13 gears, complete rebuild
14 Bolt rear axle, disc brakes, Detroit Locker, 5.13 gears, complete rebuild
3” body lift w/ new red poly Energy Suspension bushings
9” Skyjacker lift w/ all new springs
6 Skyjacker Nitro shocks
New red poly Energy Suspension bushings throughout
18.5/44/16.5 Ground Hawgs on 14-16.5 NASCAR style rims
Dual front shocks
Steering Stabilizer
A/C
Reese Class 3 hitch
1400 watt FM/CD-Bose/Infinity speakers
I am just now finishing the engine, I have to plumb some brake lines and get driveshafts and I'm on the road! I found a tailgate in the box for $100 and am going to buy panels soon.
I thought I would go ahead and post a couple of pic's of my Blaz.......ummmm BRONCO ( the blue oval must have fallen off )
:shrug
Its's got a mildly built Vortec 350 ( Edlebrock RPM performer plus cam & intake, Q-jet 750 cfm carb, steel crank, forged .060 over pistons, 10.5-1 compression ratio, balanced & blue printed, yada, yada, yada ), MSD ign., headers. 3" dual exhaust, Turbo-350 w/ extra clutches and Transgo stage 2 shift kit. extended drivelines, 5.38 gear ratio, Dana 44 w/ locker up front, 12 bolt w/ spool in rear. 11" suspension lift & 4" body lift, BushWhacker Fender Flares, 39.5 x 15 Super Swampers.
:thumbup
Well 2-1/2tonbronco went and had a little fun at the mudbogs this Sunday.
This was a poser shot with one of the guys that put on the event.
just another poser shot
Here he is makin a full pass through the pit. all I can say is it was long, deep, and nasty.
We had a great time and there were plenty of cool rides to look at, and watch run the pits. :thumbup
