Was this a kit? Any more info on the build?Put this together and promptly broke 1 piston and 2 rings. sure was fun though!
I built everything, there isn’t a kit for a bronco. I chopped up an old header and built the manifold for the turbo. Built the crossover pipe from the factory DS manifold to the turbo manifold. Used a cheap eBay Intercooler and piping kit for the cold side. Ditched the EEC-IV and wired in a microsquirt ECU. 2015 mustang GT500 injectors 57lb/hr. Soldered USCAR connectors into factory injector harness. Kirban adjustable FPR set at 43.5 psi and rising with boost. Big aluminum radiator. Currently rebuilding the bottom end with more ring gap and slightly bigger camshaft Otherwise stock bottom end.Was this a kit? Any more info on the build?
I don't. I kind of documented it on my IGDaaaayum, impressive work! Do you have this build documented somewhere?
What is that BBC going in?Wow how did I miss this thread for so long?
Here is my motor....can’t wait to hear the comments now once it gets recognized lol...FYI this is a test n tune pic...not the actual headers being run today
That motor is currently pushing my Bronco...What is that BBC going in?
Tunnel ram intake?Here is crossbreed 6.0.![]()
That looks amazing... I love the looks of a fresh engine install.A lot of work on this motor
