1 - 3 of 3 Posts
Banned
Hey guys/gals im new to the site and I just picked up my first truck.
Its a 1988 Bronco (fullsize) 4x4 (love this truck) anyways im having a problem with the passanger side door lock, i can lock and unlock it manually but if i use the switch (passanger side) it only locks and unlocks the drivers side door. Driver side is fine it just wont lock or unlock the passanger side either. what can my problem be? Please help.
Sounds like you are going to have to replace the actuator. Do a search. I am sure there are write ups on that. Check your cabling and switches before you spend any money
take the door pannel off and unplug the actuator and hook 12v to one wire of the acuator and ground the other wire if it does nothing than the actuator is bad if it ok than look at the wiring
if you dont know what an actuator is its the thing that pushes the lock up ad down has two wires going to it
1 - 3 of 3 Posts
