1 - 3 of 3 Posts
Hopefully someone can point me in the right direction. I replaced a 3 year old Red Head box that had developed slop with a new one and went ahead and swapped out to a Borgeson shaft. Ran through the recommended fill and bleed procedure. No slop in the wheel now, but the steering wheel is harder to turn that it used to be by a fair amount and it has no return to center. I suspect that my old pump is blowing by and not supplying enough pressure to help the gear box turn as easily as before? Any advice would be greatly appreciated.
if it has no return to center, and old box did and you have not change any other front end parts, highpoint on steering box may be adjusted too tight
So after driving it around for a few thousand miles, it has become pretty good...I can drive her straight down the road now!
1 - 3 of 3 Posts
