1 - 4 of 4 Posts
The power window on the passenger stop working a few days ago, but then started working again..i check for loose wire everything is fine..switch doesnt seem to be goin out or anything, but i could be wrong....any advice?
I had a Jeep that had the same problem. Check the connection from the wiring to the switch. The contacts could be corroded. Clean it up with contact cleaner or Brake cleaner. Since it is apart, put some dielectric gel on to prevent it happening again. If the contact is clean, I would also check the fusebox just in case. If all of that looks good, replace the switch.
Hope this helps.
thanks for helpin me out, i'll try that, i havent gotten to work on it lately, due to work and stuff, but i'll look at it first chance i get......yes the motor is working, they interior light dims a lilttle bit with the engine off, its jammed, idk tho, i'll look at it :thumbup
1 - 4 of 4 Posts
