1 - 3 of 3 Posts
Are any of you guys up north using the preheat shroud that sits over the exhaust manifold and feeds warm air to the air filter (there is a vac operated valve in the fresh air intake).
Mine is missing, there seems to be no aftermarket need for it so I wondered if you guys in the cold have found these parts or if they are just not used anymore. This has always been one of the things I have always tried to leave on my vehicles as it does (in my opinion) help in cold weather. Lots of guys tear it off first thing.
I took my stovepipe 23 yrs ago
now i wish I still had it!
the truck I am building will have it as the damn carb freezes up on my current one when it is around 0 degrees before the engine completely warms up
it doesn't help I have a plastic 1'' carb spacer either
probably ebay or a bone yard only place to get one
you can probably make one too from some exhaust pipe or some scrap tin
yo,
I agree with tour thinking of needing it and Risuty's.
Our ex-78 was missing most of the shroud; was lucky to find what was last fairly good shroud in local Yard.
Probably make your own.
For a YARD SEARCH on-line, I use;
http://www.hollanderparts.com/
Select All Parts
year, etc, then FORD TRUCK
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pics!
http://car-part.com/
http://api.viglink.com/api/click?fo...427 - FSB Forums&txt=http://www.picknpull.com
This is a Company name w/yard locations in various states
Also for obsolete parts by Ford Part Number long version
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
1 - 3 of 3 Posts
